Browse Forums General Discussion Re: Which gas instantaneous hot water system? 9Oct 14, 2012 9:09 am Wow that's a pretty strong vote for the rinnai systems! Have to get some quotes. Liliana Just make sure you have a good plumber I do now, won't be using the original guy that's for sure. Re: Which gas instantaneous hot water system? 10Oct 14, 2012 5:33 pm try the gstore in malvern dave, we got a great price from them on ours. Re: Which gas instantaneous hot water system? 11Oct 17, 2012 10:28 am Thanks, will keep them in mind. Probably just get a classic 26 model rather than the Enviro. Have to do a bit of research on that one to see if the extra outlay is worth while but my gas bills aren't obscene. Re: Which gas instantaneous hot water system? 12Oct 18, 2012 4:29 am Charnley Whatever you choose however make sure your top temp is 65 degrees not 50. 50 is not hot enough in the Kitchen Just a note that if its connected to solar the max temp in Victoria that it is allowed to deliver anywhere in the house is 50c. Rennai rate there units on litre per minute at +25c. So rennai 26 will deliver up to 26 ltr p/m at 25c. Re: Which gas instantaneous hot water system? 13Oct 18, 2012 9:24 am Thats a little wrong. it should be 26 litres per minute with an increase of 25 degrees. So if the water is 10 degrees to begin with then it will be 26 litres per minute at 35 degrees. Re: Which gas instantaneous hot water system? 14Oct 19, 2012 4:00 am B STAR Thats a little wrong. it should be 26 litres per minute with an increase of 25 degrees. So if the water is 10 degrees to begin with then it will be 26 litres per minute at 35 degrees. Yup I live in melbourne our water is aways cold I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20237 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14076 instantaneous is three phase and draws heaps of current, the efficiency comes from not storing it so you don’t lose heat to the environment. The problem is it is not… 5 1466 |
