Browse Forums Paving & Concreting 1 Jan 30, 2012 5:00 pm I have finished my paving project and now wish to seal it. I used concrete paver over sand with crushed rock base. It's been laid for 4 weeks now. Do I still need to acid wash it or a few passes of high pressure water will do? What sealers do you recommend and what's your experience with it? Thanks. Oxford 22 @ Stage12a Point Cook Site Cut : 05/03/2010 Slab Pour : 24/03/2010 Frame Inspected : 06/04/2010 Pre-plaster Inspection: 22/04/2010 PCI: 16/07/2010 Final Inspection: 30/07/2010 Landscaping: who knows??? MyHomeoneThread Our Oxford22 Blog Re: Cleaning and Sealing Pavers 2Jan 30, 2012 6:24 pm The cleaning process is dependant on the type / brand of paver, what brand etc do you have? Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Cleaning and Sealing Pavers 3Jan 30, 2012 9:42 pm I used adbri havenbrick/slab.. Charcoal color, ithink.... Oxford 22 @ Stage12a Point Cook Site Cut : 05/03/2010 Slab Pour : 24/03/2010 Frame Inspected : 06/04/2010 Pre-plaster Inspection: 22/04/2010 PCI: 16/07/2010 Final Inspection: 30/07/2010 Landscaping: who knows??? MyHomeoneThread Our Oxford22 Blog Re: Cleaning and Sealing Pavers 4Feb 01, 2012 9:17 am Depending on how clean the area is will depend on whether or not you need to clean it. If you have stains from animals, trees, BBQ etc then yes clean it. If you have nothing like this then broom it down and seal it. Re: Cleaning and Sealing Pavers 5Feb 01, 2012 8:32 pm Hi Miteq, I've recently laid Austral Clay brick pavers and need to seal them - I have approx 80m2 in total. I have a some vanadium salt staining which I plan to remove first with chlorine bleach. Can you advise a suitable sealer? Neil and Rachel Finally completed the Hartley 361 with Dennis Family Homes in Mernda Villages..... Now for the Landscaping Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6700 Appreciate that Chippy. I won’t do sand under pavers and will connect all up under pavers, however I was going to do: 1) Roadbase compacted with manual hand tamper 2)… 10 18551 |
