Browse Forums Flooring & Floor Covering Re: Garage floor covering 41Jan 02, 2014 10:29 pm I considered vinyl for the garage but it can quickly get expensive, I mean $35/m for 6*6m , $1260 for the garage floor?! And that's assuming a do it yourself job. 2nd hand/seconds might work fine, vinyl tiles would look good to it's all a question of how much you want to spend and what you can get. In retrospect I was considering how much it would cost to "hone" the concrete, polished concrete would be expensive but I think you can seal it fairly well a little cheaper than that without the pretty look... Re: Garage floor covering 42Nov 23, 2015 12:16 pm theanonyuser In retrospect I was considering how much it would cost to "hone" the concrete, polished concrete would be expensive but I think you can seal it fairly well a little cheaper than that without the pretty look... You could utilise a high-solids tinted or clear epoxy at a relatively cheap price point for a double garage. (Assuming you DIY). Dymark is a water-based system, you can see some results here: viewtopic.php?f=22&t=61624&p=1435565#p1435565 All Purpose Coatings - Ashford Corporate Group http://www.epoxysupplies.com.au - PH: 1800 4 EPOXY (1800 437 699) Re: Garage floor covering 43Nov 25, 2015 10:58 am The Dymark system that I did my floor was not water based at all. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Garage floor covering 44Nov 25, 2015 12:40 pm bpratt The Dymark system that I did my floor was not water based at all. Interesting! You're right, reading the MSDS of the kits sold at Bunnings shows they are a solvent based product. However they're using large quantities of solvent (Xylene) to thin the product and reduce the solids content. An interesting revelation to myself either way! All Purpose Coatings - Ashford Corporate Group http://www.epoxysupplies.com.au - PH: 1800 4 EPOXY (1800 437 699) got it. thanks. I was looking for word ' Adobe' and added filter. all good. 12 14486 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17528 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16567 |
