Browse Forums Kitchen Corner Re: Pros and Cons on handle-less cabinets/cupboards please 5Aug 12, 2011 12:07 pm Check out our renovation in progress at http://www.ourdiydream.com Follow us on facebook http://www.facebook.com/ourdiydream Check out what we are 'pinning' http://pinterest.com/ourdiydream/ Re: Pros and Cons on handle-less cabinets/cupboards please 6Aug 12, 2011 1:21 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Pros and Cons on handle-less cabinets/cupboards please 9Aug 14, 2011 8:26 am Ive got push ones, I couldn't have overhang for some reason. I don't mind the push, I get prints but handles, pull or push I wipe down where hands go anyway. You can't slam them either which is good Re: Pros and Cons on handle-less cabinets/cupboards please 10Aug 15, 2011 6:31 pm We used unsprung hinges and touch catches, then most of the time put it back to normal hinges and handles, yep that's right, most of the customers felt it looked unfinished, I thought it looked crap myself. But each to his/her own Re: Pros and Cons on handle-less cabinets/cupboards please 11Aug 15, 2011 7:28 pm Personally handless cupboards arent a nice look but each to their own. We chose handles http://lindeman28.blogspot.com - Our building blog Re: Pros and Cons on handle-less cabinets/cupboards please 12Aug 16, 2011 7:31 am Trewman Personally handless cupboards arent a nice look but each to their own. We chose handles I think this handless kitchen looks good, but then I did make it! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Pros and Cons on handle-less cabinets/cupboards please 14Aug 16, 2011 9:51 am I think it's just a thing where im so use to handles it throws you out a bit cos they don't look like cupboards that kitchen does look fantastic http://lindeman28.blogspot.com - Our building blog Re: Pros and Cons on handle-less cabinets/cupboards please 15Aug 16, 2011 10:48 am aj8 CuttingEdgeKitchen, the kitchen you made is really wow ! is that 2-pack ?? Thanks, I am hopeing to get it into a few magazines. The white is 2pac Polyurethane as is the colour between drawer fronts. The brown colour is a laminate timber grain. All the top doors open upwards and the oven and panty are in the room to the left. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Pros and Cons on handle-less cabinets/cupboards please 16Aug 16, 2011 1:07 pm We used the Aluminum section between drawers, it looks great too. That is a nice kitchen, think you get away with it because there is no base doors Re: Pros and Cons on handle-less cabinets/cupboards please 17Aug 16, 2011 1:31 pm Wow....like that kitchen CEK!! and imho, what makes it really appealing is the undermount rangehood...then again that's what I've got so suppose I'm biased. In saying that I do have handles on the underbench drawers. I also like the symmetry between the overheads and the drawers...hate things not lining up!! LOL Re: Pros and Cons on handle-less cabinets/cupboards please 18Aug 16, 2011 1:56 pm Amazing looking kitchen, especially like the floating bulkhead over. Are your overhead cupboards full height and pull up or swing doors and do you have magnetic catches on them. Re: Pros and Cons on handle-less cabinets/cupboards please 19Aug 16, 2011 2:00 pm Darren Stewart We used the Aluminum section between drawers, it looks great too. That is a nice kitchen, think you get away with it because there is no base doors Like these? A kitchen I built for Amanda Taberra Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Pros and Cons on handle-less cabinets/cupboards please 20Aug 16, 2011 2:02 pm silversurfer Amazing looking kitchen, especially like the floating bulkhead over. Are your overhead cupboards full height and pull up or swing doors and do you have magnetic catches on them. They are acutally two cabinets one ontop of the other. The bottom timber grain cabinets are 330mm deep with lift up doors. The top white cabinets are 450mm deep also with lift up handles. There are lights in the bottom of the top cabinets that overhang the timber grain cabinets. (there not on in the photo) No magnetic catches. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 11999 at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61346 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6346 |
