Browse Forums Building A New House Re: Porter Davis homes 3302Sep 30, 2011 11:56 am Porter Davis Homes Questions? Call 1800PORTER Mon - Fri 9am-8pm Sat - Sun 10am-4pm info@porterdavis.com.au http://blog.porterdavis.com.au/ http://www.porterdavishomes.com.au Re: Porter Davis homes 3303Sep 30, 2011 1:21 pm Site cut: 2 June 2010 Slab Poured: 2 Oct 2010 Frame Stage: 12 Oct 2010 Lock up: Dec 2010 Fixing Stage: March 2011 http://karasdreamhome.blogspot.com/ Re: Porter Davis homes 3306Oct 01, 2011 5:29 pm Does anyone know how many amps you get your electricity supplied to the house. Ive tried asking this question to PD and they said its up to the authority. Is this right? My understanding is PD will need to ask authority to provide connection to the house, hence, they need to let authority know how many supply amps required up to a maximum of 63Amps for Victoria. I tried to let PD know that I wanted this much amps to go into the house and not the lower one which is 40Amps. Somehow, they didnt want to let me know and i found this very annoying!! this is standard process that one have to go through when applying for a new electrical connection. I am considering installing 25amps power ducted AC 16kW single phase. With 63 amps supply, I should have enough power to do this without the need to upgrade to a 3 phase supply. Any thoughts guys? Re: Porter Davis homes 3307Oct 01, 2011 7:18 pm You have to apply to the network for the additional supply capacity. Depending on the area you are in will determine the network you are on. For example Powercor maximum standard is 40amps. If you want the 63amps you would make an application for increased capacity supply that you would submit. DH who is an electrician just yelling out from loungeroom for your answer Re: Porter Davis homes 3308Oct 02, 2011 10:18 am thebigbuild You have to apply to the network for the additional supply capacity. Depending on the area you are in will determine the network you are on. For example Powercor maximum standard is 40amps. If you want the 63amps you would make an application for increased capacity supply that you would submit. DH who is an electrician just yelling out from loungeroom for your answer Thanks bigbuild! I will be building in the west. It might've been powercor supplying power to the estate. Will give developer and powercor a call. I thought powercor max standard is 63amps? Porter Davis homes 3309Oct 02, 2011 7:45 pm Just started pd kitchen thread. Never know what we could ask for so hopefully this will help, sharing pics etc. Re: Porter Davis homes 3310Oct 02, 2011 8:18 pm Hi Guys, Just wondering what you need to do to get your internet / phone connected? We already have phone and internet points in the house. Do PD also connect the wires from our house to the network and then we just have to call telstra to have the service provided or to we have to get telstra to connect the house up? Thanks! Building the Drysdale 30 Wallara Waters, Wallan My Blog : http://www.ourwallanhome.blogspot.com My thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=50975 Porter Davis homes 3311Oct 02, 2011 8:52 pm cattycatcat Hi Guys, Just wondering what you need to do to get your internet / phone connected? We already have phone and internet points in the house. Do PD also connect the wires from our house to the network and then we just have to call telstra to have the service provided or to we have to get telstra to connect the house up? Thanks! You will need to contact Telstra who will connect you at the exchange and set up your service, which will cost you about $300 Re: Porter Davis homes 3312Oct 02, 2011 8:59 pm Roshi Hi Fingers Crossed, Have you hit the 3 months maintanance? Yes 3 months in and loving it - still have little isssues, also heard that the Bundoora office has closed - Site cut: 2 June 2010 Slab Poured: 2 Oct 2010 Frame Stage: 12 Oct 2010 Lock up: Dec 2010 Fixing Stage: March 2011 http://karasdreamhome.blogspot.com/ Re: Porter Davis homes 3313Oct 02, 2011 9:08 pm Rups cattycatcat Hi Guys, Just wondering what you need to do to get your internet / phone connected? We already have phone and internet points in the house. Do PD also connect the wires from our house to the network and then we just have to call telstra to have the service provided or to we have to get telstra to connect the house up? Thanks! You will need to contact Telstra who will connect you at the exchange and set up your service, which will cost you about $300 Awesome thanks I've read where other people have been charged about $1000 for them to dig a trench and lay cables. As long as PD does this as standard then I wont have the extra charge by telstra! Building the Drysdale 30 Wallara Waters, Wallan My Blog : http://www.ourwallanhome.blogspot.com My thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=50975 Re: Porter Davis homes 3314Oct 02, 2011 9:15 pm cattycatcat Rups cattycatcat Hi Guys, Just wondering what you need to do to get your internet / phone connected? We already have phone and internet points in the house. Do PD also connect the wires from our house to the network and then we just have to call telstra to have the service provided or to we have to get telstra to connect the house up? Thanks! You will need to contact Telstra who will connect you at the exchange and set up your service, which will cost you about $300 Awesome thanks I've read where other people have been charged about $1000 for them to dig a trench and lay cables. As long as PD does this as standard then I wont have the extra charge by telstra! In my Tender Doc they quote for "Telstra underground trench" - $308 and of course you are able to add points for extra cost. Once finished you call Telstra to connect you ($300) but they don't have to be your ongoing provider. Porter Davis homes 3315Oct 02, 2011 9:44 pm cattycatcat Rups cattycatcat Hi Guys, Just wondering what you need to do to get your internet / phone connected? We already have phone and internet points in the house. Do PD also connect the wires from our house to the network and then we just have to call telstra to have the service provided or to we have to get telstra to connect the house up? Thanks! You will need to contact Telstra who will connect you at the exchange and set up your service, which will cost you about $300 Awesome thanks I've read where other people have been charged about $1000 for them to dig a trench and lay cables. As long as PD does this as standard then I wont have the extra charge by telstra! Strangely enough the telstra connection from the street pit to the side of your house isn't standard, and as JLD said that's a further $308 as described. Talk to your BC about getting it added in... Re: Porter Davis homes 3316Oct 03, 2011 6:08 pm Thanks![/quote] You will need to contact Telstra who will connect you at the exchange and set up your service, which will cost you about $300[/quote] Awesome thanks I've read where other people have been charged about $1000 for them to dig a trench and lay cables. As long as PD does this as standard then I wont have the extra charge by telstra![/quote] Strangely enough the telstra connection from the street pit to the side of your house isn't standard, and as JLD said that's a further $308 as described. Talk to your BC about getting it added in...[/quote] Can someone please let me know under what section I can locate this charge in my contract, We have only been charged for "Telstra Smart Wiring Light Package" $1623. Does this seem correct! Porter Davis homes 3317Oct 04, 2011 11:08 am It's a completely separate line item in the contract, and is not 'bundled' with any other pack (like the smart wiring one for example). Nor is it included in the standard services connection item, which is only for water, gas, elec and waste. You will need to ask your BC to add it in, as it is not a standard item they include (beats me as to why not!) Ours is written as "provide Telstra underground cable trench up to 20m" $308. Not sure what heading it would appear under in your contract as ours was done as a PCV Re: Porter Davis homes 3318Oct 04, 2011 11:16 am Hey Rups & Leanne, When is your land scheduled to title? I can’t wait to watch your land transform into a home. Also can’t wait to see all your inclusions, the house is going to look really nice from what I have read on your blog. Keep us all updated pls.... Porter Davis homes 3319Oct 04, 2011 11:48 am Hey there T, Just posted an update on this over on the Saltwater thread, but we got a letter from our solicitor yesterday advising that the land had received council compliance and was now at the Titles office...! So, hopefully settlement will be scheduled somewhere in the next 2 weeks. The last 4 letters we've had from the solicitor have been to advise of delays, so this was very welcome and turned the excite-o-meter up a notch! One of the advantages (and to some degree, a disadvantage) of being land delayed is the opportunity to scrutinise every option, selection and decision made and continually validate them. As painful every conversation my wife and I have had that started with "I've been thinking about...." or " I don't think I like the...", we're now 100% happy with the spec of our house, and our BC has been VERY accommodating of our many changes, although most of them have ended up with a lot more money in PD's coffers Friends of ours are building a Churchill just around the corner, so their buid has been a surrogate build for us while we wait! So... just need to complete settlement, get the council building permit and finalise the construction drawings and away we go... Bets on for a (concrete) slab this side of Christmas Btw, your house is looking fantastic and is coming along at an incredible rate of knots!!! Porter Davis homes 3320Oct 04, 2011 12:11 pm Rups Hey there T, One of the advantages (and to some degree, a disadvantage) of being land delayed is the opportunity to scrutinise every option, selection and decision made and continually validate them. +1 I think if my build were to have started straight away I would still have been happy, and probably saved some money too! I think reading on here doesn't help either, now I want to add the trench as discussed above, but I'm too scared to email my BC again as I think she's probably sick of me! Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report 3 12345 Ask for references and speak to them. If they are defensive or try to avoid the request, walk. 1 74717 I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 105603 |
