Browse Forums Bathrooms and Laundry Re: Shower Screen Dilemma with pics 3Jun 29, 2011 12:49 am Could you have a floating wall/feature column at the end of the glass panel? Ours is 2m high and I think about 40cm wide. The display had their column completely tiled in a small brown strip feature tile. Ours is white with one central glass tile strip (you can see the reflection in the mirror). Our screens are semi-frameless. The panel at the entrance is a complete, fixed panel and the door panel is on the otherside of the column. Speaking from experience, absolutely insist that your tiler checks, double checks and triple checks the fall of the floor tiles. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Oceanic with Nautilus upgrades. Handover 8 September 2010 Re: Shower Screen Dilemma with pics 4Jun 29, 2011 10:19 am Does the glass have to go that far? That is can you just have the 1500mm glass and no wall? This will allow you to still have the look you want. Or do you require the extra length? Re: Shower Screen Dilemma with pics 5Jun 29, 2011 11:32 am That looks really nice Oceanus2, I wonder if that was where the suggestion for how to do ours came from.
kdgirl: we are having a roof mounted shower head in the middle of that area and a shower rail in the standard position. Your shower screen has failed in the way it is designed to fail with tempered glass. You could replace it with laminated safety glass but make sure it has AS standards logo on it 1 11184 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7074 2 4496 |
