Browse Forums General Discussion Re: Builder needed 4Mar 17, 2011 6:48 pm Pinchy jedaking Hi ! im new here . id like to know which is the best builder to build a house here in cranbourne north. thanks Wow, you really are new here. What is your budget? What type of house do you want to build? Single storey? Double storey? Townhouse? Large? Small? How big is your block? What are your estate covenants? Have you looked at any display homes? Have you spent much time reading the information posted all over this forum? I think once you can answer some of these questions you will have a better idea of what you are looking for in a builder. Good luck. our budget is $350,000 to $360,000 including our land is 320sq m ($192,000) . we also want a single story Re: Builder needed 5Mar 17, 2011 6:59 pm Sounds like you need to go and hit your local display village and check out houses and floor plans from all the builders. If -you- don't do your own research -you- wont get very far 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Builder needed 6Mar 17, 2011 7:12 pm You really need to do enough research to at least know what questions to ask. Simply coming in to a forum like this and asking which is the best builder is a bit like asking "how long is a piece of string". No one can possibly give you an answer. Go to your local display villages, talk to the sales reps at each house, gather information and narrow down your choices. You can even research house options online. If you had spent some time reading at least some of the pages and pages of information which is freely given in this forum by so many people you would surely know enough to know that you were asking the wrong question. Re: Builder needed 7Mar 18, 2011 7:44 am There a quite good display villages in Cranbourne. So you wont need to travel far. Being such a small block, you are going to be limited as to which designs you can put on your block. Looking at your budget. $360000-$192000 = $168000. I'm guessing $168k will include extras, landscaping, stamp duty etc etc. So really you want to look at designs with a base price of around $120k - $130k. How many bedrooms do you need, how wide is your block, etc etc. lots of variables before you can go from there. Once you have picked 2-3 homes that you like and you can build, then you can start selecting the builder. At the end of the day, all the builders are pretty much the same. You will read horror stories about all of them. Just remember that people generally write about bad experiences, rather than good. At the end of the day, it comes down to the individuals that work on your home. Evey builder has good and bad CSO's, and good and bad build crews. Milesy Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20413 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6901 |
