Browse Forums Heating, Cooling & Insulation Re: Wood Heater, what do you think? 2Nov 20, 2007 9:18 am Nothing beats wood heaters for ambience and throwing out heat, but we lived with one for 8 years and are now very pleased to be pressing a button to heat our house. My 2 cents on the pros and cons of wood heaters are
Pros Great heat output Looks great Cheap to run when you have availability of free wood. Cons Lots of work, collecting, chopping, storing wood. Lots of dust and dirt in the house (I was vacuuming jarrah dust off my walls every spring) and wood chips dropping on the floor near the wood bucket. Environmental pollution, if wood is too green it smokes. (We lived in a valley town where almost everyone had a wood heater, and some days you couldn't see 100 m away!!) kezza ![]() Re: Wood Heater, what do you think? 3Nov 20, 2007 10:18 am Yes that is my biggest fear - getting up in the cold winter, having to start the fire & wait for the place to warm up.
Dust, there is that much dust where we live at the moment (not fire related) that even my laptop has refuses to work every few months and has to get sent away for a clean, I'm sure anything would be an improvement, besides hopefully there won't be a need to heat for half the year. We have plenty of trees on our block but I'd be hesitant to let Hubby chop them down - after all we didn't buy the block for free firewood! ![]() Not sure if it's a standard inclusion or not, but I will probably take the option of having on gas port installed in the main living area, juuust in case. Especially for the days you have to work - no point having the fire going for no-one, or if we happen to run out of wood! I suppose in some ways there are upsides to the downsides of wood fires. If you're too lazy to light it, then you save on heating costs ![]() Of course our house will be so environmentally efficient that we won't even need a heater! LOL wishful thinking hey! Re: Wood Heater, what do you think? 4Nov 20, 2007 10:39 am ![]() Yes that is my biggest fear - getting up in the cold winter, having to start the fire & wait for the place to warm up. Dust, there is that much dust where we live at the moment (not fire related) that even my laptop has refuses to work every few months and has to get sent away for a clean, I'm sure anything would be an improvement, besides hopefully there won't be a need to heat for half the year. We have plenty of trees on our block but I'd be hesitant to let Hubby chop them down - after all we didn't buy the block for free firewood! ![]() Not sure if it's a standard inclusion or not, but I will probably take the option of having on gas port installed in the main living area, juuust in case. Especially for the days you have to work - no point having the fire going for no-one, or if we happen to run out of wood! I suppose in some ways there are upsides to the downsides of wood fires. If you're too lazy to light it, then you save on heating costs ![]() Of course our house will be so environmentally efficient that we won't even need a heater! LOL wishful thinking hey! If you were going to use it for heat, then you wouldn't use one like that. A coonara type on would be more efficient. Re: Wood Heater, what do you think? 5Nov 20, 2007 10:58 am Not sure exactly where you are, but if you aren't on mains gas and you need to buy bottles, then you don't want to be heating your house with gas, as it is so expensive. When we lived in a (VERY) cold SW WA town we had a slow combustion wood fire (with associated dust, dirt etc, but great heat) and the wood was fairly cheap, but we also put a largish reverse cycle air conditioner in the living area which meant that in late spring and early autumn when you only needed heat for an hour in the morning or a bit at night we used that instead of the wood fire. But the rule of thumb was you only lit the fire once in winter (but it stayed lit for 6 months!!) ![]() ![]() Re: Wood Heater, what do you think? 6Nov 20, 2007 11:07 am Hi Pebbles,
As per Al said, these glass fireplaces are great - but they are for show and tend to burn a lot more wood than the equivalent other styles for heat output. You really need what is known as a combustion fireplace to be of any use if it is your 100% heating resource in winter. One with lots of heater blocks also work better as they store lots of heat that is relaesed during the night/day when on low. They also have glass fronts. Once lit - you let it burn 24x7 stoke it up at night (the fire !!! I mean) ![]() ![]() Then you shut it down when you walk out the door, and that night when you get home frowork it's still burning and ready to do it all again. ![]() A wood heated house is actually warm all the time - but yes there is the dust and work involved - that keeps you fit ![]() I used to use around the 3 ton per year in the cold Adelaide hills. But I know of others who use 5 ton. My fireplace when shut down with good coals going lasts 2 days and I can open it up - pop in some paper, twiggs etc, the coals fire up again and away it goes. Check out these brands which I have used and like - plus more info at the fireplace association web site. Nectre - SA Made Kent Coonarra - Vic Saxon - Tassie http://www.homeheat.com.au/ Steve Re: Wood Heater, what do you think? 7Nov 20, 2007 11:44 am We have a reverce cycle split system so can set it to come on in the morning to warm the place up a little before the fire gets going (if it hasn;t been lit the night before) or to come on in the arvo if we have been out for the day.
Other than that we love our fire, a good fire with a couple of hefty bits of timber will burn through the night and still put out warmth in the morning. Wood fires despite the smoke are one of the 'greenest' forms of heating Re: Wood Heater, what do you think? 8Nov 20, 2007 12:33 pm Hi Dukemeyer,
Sorry but wood heaters aren't very green at all. We promote the RTA Solid Fuel heater buyback program here at work, and the following is info straight out of the brochure: "Residential wood burning (the use of fireplaces, pot-belly stoves and open fires) causes up to 40% of winter air pollution in the Sydney metro area. This pollution is made up of very small particles that can be taken directly into the lungs and contains a number of toxic and cancer causing agents. The smoke not only pollutes the air but also reduces visability and causes physical discomfort for those with respiritory problems, especially older people." The brochure goes on to suggest cleaner heating alternatives that are eligible for the $500 rebate to replace your wood heater and the best are (in order) Solar active (using solar panels) Solar passive (good design) Pellet fires If you're looking in the $3-4000 range, I'd consider the Eco-smart Fire, an Aussie invention which uses de-natured alcohol (metho) to run on. The only by-products are heat, and a bit of steam and a little bit of co2. More info at www.ecosmartfire.com.au I saw one at the Home Show and LOVED IT! They look fab. I'm saving my pennies for one for my new place. If you are interested in the RTA's $500 wood heater rebate visit www.rta.nsw.gov.au For tips on cleaner wood burning, you can get a copy of the brochure Hot Tips For Cleaner Wood Burning from the RTA website too. Here are some tips to reduce wood smoke 1. Use good dry wood as it will provide up to 40% more heat 2. Start out using plenty of paper and kindling. Paper produces a hotter fire more quickly than firelighters. 3. Keep fire burning slightly by setting the air controls high enough to prevent the flame dissapearing 4. Only use larger pieces of when when the fire is established 5. Check your chimney and flue every evening to make sure the fire isn't producing too much smoke. If you are creating too much scmoke, you may be given a Smoke Abatement Notice from an authorised officer which can result in fines. Also, I'm pretty sure you can't install a wood heater in a new house in Sydney because of the pollution they cause. Building a Jandson Espirit in Pennant Hills "What is the use of a home, if you haven't got a tolerable planet to put it on?"Henry Daniel Thereau Re: Wood Heater, what do you think? 9Nov 20, 2007 1:08 pm Lots of great and very helpful info. Thanks!
On the wood topic - Must admit my husband & I both thought that the fire heater picture would "throw out" more heat, we'll have slate tiles (double brick house) to soak it all up. However I have read that with proper technique you can keep the fire going & going with relative ease. But yes, throwing out more heat and burning wood goes hand in hand - certainly makes sense and I didn't think of it that way! Great tip Yak Chat, I will certainly check out those brands, and pass them onto hubby, he's the one really keen on the looks of this one, but he is also a big fan of pot bellies. Great point about the gas too, yes we would be on bottles. It was only ever meant to be as a backup though. Solar electric heating sounds ideal really, we may look into solar electricity later on down the track probably well after the place is built. We're on bottles where we currently live ($120 a pop) and gosh seem to go through one every 6 weeks in winter! The place certainly isn't as big as the new one will be but it's not very enviro efficient either (curtains / draughts etc). Re: Wood Heater, what do you think? 10Nov 20, 2007 1:49 pm Quote: But yes, throwing out more heat and burning wood goes hand in hand - certainly makes sense and I didn't think of it that way! Pebbles, not quite so..... The modern combustion fires actually do a thing called second stage burning, ie the wood burns, which releases gases and a good combustion design will also burn this gas (versus going straight up the chimney) so a good combustion fire uses less wood per heat output than than the glass one you've pictured would, and with a lot less emissions. But as said above- you need good dry timber and to run it properly - as it's not a press the button device that will automatically do the job. Steve Re: Wood Heater, what do you think? 11Nov 20, 2007 3:36 pm This is the website where we came across it.
http://www.thefireplace.com.au/ Reading the blurb it sounds like a pretty efficient design, but I wouldn't know if it was just a good sales pitch or not! Quote: The Carousel features a patented internal design that develops a near complete burn with a minimum of emission. Quote: THE CAROUSEL FREESTANDING WOOD HEATER - How it works A: Race ring prevents entering cooler air from adding to the updraft and heated air from circulating against the glass. B: Heat radiation through the glass panels is excellent. C: Combustion-created heat currents twist up inside the wall of incoming air to create the 'cyclonic' appearance. D: The swirling, slow movements of air currents around and over the fire insure a thorough burn and minimum residue. E: High velocity air enters along glass walls forming a moving air curtain. The glass is kept clean by the flow of incoming fresh air moving around the interior walls. F: A large baffle plate above the fire slows the rising currents of air and promotes thorough burning and a softer, longer lasting fire. Re: Wood Heater, what do you think? 12Nov 20, 2007 8:07 pm It'd be interesting to see if they have an efficiency rating for it.
They seem to have most of the needs of a good fireplace - except the thermal mass to store and release the generated heat. There is some detailed information here, that also talks about pellets and their low pollution and suitable environments. http://www.environment.gov.au/atmosphere/airquality/publications/report4/chapter3.html Ideally we should not need any heating on OZ. I've lived in a modern house in sweden with zero heating, yet a constant indoor temp of 22 degrees remained while outside temps of 8 at night and 15 to 20's during the day. Most of our oz housing needs temperture range could cope with that. But old habits die hard don't they - fireplaces are nice, so is saddling up the horse and buggy to go to work. ![]() Steve Re: Wood Heater, what do you think? 13Nov 21, 2007 1:38 pm Thank you, I certainly have a bit more research to do on the topic.
And you know considering how much time we all spend working to pay for our nice new houses you'd think it would be even more true - we don't need heat because we're not spending enough time at home! Re: Wood Heater, what do you think? 14Nov 21, 2007 2:44 pm ![]() Hi Dukemeyer, Sorry but wood heaters aren't very green at all. We promote the RTA Solid Fuel heater buyback program here at work, and the following is info straight out of the brochure: "Residential wood burning (the use of fireplaces, pot-belly stoves and open fires) causes up to 40% of winter air pollution in the Sydney metro area. This pollution is made up of very small particles that can be taken directly into the lungs and contains a number of toxic and cancer causing agents. The smoke not only pollutes the air but also reduces visability and causes physical discomfort for those with respiritory problems, especially older people." How is this proving fires not GREEN? Some pollute the air with smoke but smoke doesn't damage the environment, just peoples lungs. Using smartburn and/or a slow combustion fire, smoke can be almost entirely eliminated. An average forest fire will dwarf almost any citys fire pollution. CO2 is used in a cyclical way with home fires so no extra gets put into the system. Any soot actually reduces the tempreature by reflecting the suns rays. Compare this with gas or coal generated electricity and it becomes clear that from an environmental point of view particuarly WRT add to CO2 levels, fires are worth considering. Just an alternate perspective. Re: Wood Heater, what do you think? 15Nov 21, 2007 7:33 pm lrhodes1, your link didn't work for me.
I think there are probably more ways than one to define green as well. Wood is a renewable resource, fires are a part of nature with certain trees even rely upon it to germinate. Eucalypt forests are an example in the south and all the fires you get in the build up to the wet season in the Top End as well. No more chemicals would be released compared to what was taken in during growth - including the C02. Metho is a man made (or refined chemical), I forget the formula but essentially a type of hydrocarbon?. Either way I'm open to new ideas, and it certainly sounds interesting. Although I must say some times people do try to re-invent what nature has already invented itself, and usually the scientific discoveries which are based on what nature has already created that turn out to be the best ones. Better go now, (and nope I haven't even been drinking ![]() Re: Wood Heater, what do you think? 16Nov 22, 2007 11:05 am Quote: Yes that is my biggest fear - getting up in the cold winter, having to start the fire & wait for the place to warm up. Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Wood Heater, what do you think? 17Nov 22, 2007 11:56 am Pebble no fear, despite it's awful smell and taste Metho is simply de-natured alcohol (ethonol) The de-naturing agent causes the smell and taste and is deliberately added to the pure alcohol, otherwise derros would drink it even more! ![]() More info about the system at http://www.ecosmartfire.com/default.php under about ecosmart, then The Fuel 3timesbuilda, there is some good info about woodsmoke pollution here: http://www.epa.nsw.gov.au/woodsmoke/index.htm and http://www.epa.nsw.gov.au/woodsmoke/resources.htm Theres actually a NSW Govt forum on tomorrow about air pollution greenhouse gas emissions, I went to the previous workshop, very interesting. The information I could find focuses mostly on human health, though air pollution is widely accepted as an environmental and health issue. Links are increasingly being formed between gases/particulates that are both air polluters and greenhouse gasses, eg carbon monoxide, thats enough for me to feel that wood fired heaters aren't green. Building a Jandson Espirit in Pennant Hills "What is the use of a home, if you haven't got a tolerable planet to put it on?"Henry Daniel Thereau Re: Wood Heater, what do you think? 18Nov 22, 2007 12:26 pm Quote: despite it's awful smell and taste Metho is simply de-natured alcohol (ethonol) The de-naturing agent causes the smell and taste and is deliberately added to the pure alcohol, otherwise derros would drink it even more! ![]() If that's the way they still produce it, it's a relatively green product. Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Wood Heater, what do you think? 19Nov 22, 2007 2:38 pm Meth - sorry! I must have been thinking of turps!
I had male chemistry teachers, and it was their personality and teaching methods that made chemistry a great subject - they made it fun to learn. Having good teachers makes a big difference. Re: Wood Heater, what do you think? 20Oct 10, 2013 7:33 pm There are some great, efficient wood heaters about - eg Euro Fires - using European technology that ensures a long burn and won't use too much wood. HOWEVER - DO NOT EVEN THNK ABOUT buying a STOVAX RIVA STUDIO, really only decorative as they go out quickly and cannot really keep your house warm. All bottom fire bricks on ours were shattered after less than 12 burns - guess what - we were told by the retailer in Mornington Victoria and the distributor there was no warranty!!! Really bad heater and really bad service, we are devastated and very unhappy. An EXPENSIVE MISTAKE!!! ![]() ![]() ![]() ![]() 0 1951 DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 7169 My Electrical roughing is going on. What type of Outdoor heater recommended in Alfresco sized 3000mm x 3000mm below. I asked electrician to give 15amp power point in… 0 2347 |
