Browse Forums Landscape & Garden Design Re: Front garden - help with plant selection 7Oct 04, 2010 10:18 pm my new build thread- Ben Trager https://forum.homeone.com.au/viewtopic.php?f=31&t=89826 my switch build thread (2011) https://forum.homeone.com.au/viewtopic.php?f=31&t=36569 Re: Front garden - help with plant selection 9Oct 05, 2010 12:41 am I went outside once. The graphics were alright, but the gameplay sucked! Settlement:22nd June Slab:27th August Frame:16th Sept Bricked:21st Oct Roof:24th Nov Linings HANDOVER23rd March! Re: Front garden - help with plant selection 11Oct 05, 2010 2:48 pm Something just occurred to me. When I was looking at our plans last night, I noticed that where the verge tree is marked out on the plans is actually just inside the boundary of our land, and not on the council side. Since the tree is on our property, does that mean we can just remove it anyway? New beginnings. Re: Front garden - help with plant selection 12Oct 06, 2010 12:26 am Yep...if it is on your property You would have been given the generic council answer earlier. How would they know that exact tree? Re: Front garden - help with plant selection 13Oct 06, 2010 12:30 am They regulate trees for a few reasons. Councils now have to plant a certain amount of trees in new areas like yours. This is for enviro reasons and also to make the place look pretty. Now if people start ripping them out, that buggers what they are doing. If they rip them out and replace with a tree that will cause "issues" and stuffs the suburbs look they are after, then that creates issues and ultimately costs them and you money in one form or another. This is why making a good tree selection and discussing with your council's parks and gardens supervisor as too what is an informed suitable alternative is often doable unless they are jerks Re: Front garden - help with plant selection 14Oct 12, 2010 11:30 am Council have been out to look at the tree. The guy I spoke to said he is reluctant to stake it, and will instead get someone to balance out the branches so there aren't so many on the driveway side. Clearly they take a different view to you, Fu! New beginnings. Re: Front garden - help with plant selection 15Oct 13, 2010 12:32 am I would be reluctant to stake it also. I think I mentioned that if you stake it, it will just go over in time to come... years away. He is right on the money to start shaping it. They may take some of the upper branches away to lower the centre of gravity. Although, the costs of clipping and prunning the tree to shape over coming years (it won't be a one of thing and you'll need council to return each year) They may as well rip it out and start again. The tree has little hope as it has gone over because it has poor root structure, so that will be unlikely to change and will fall over in 15 years or so. Anyway, just entertain them and then in a few years when no one cares get a mate to back over it with a 4wd and Ooops! It needs replacing Re: Front garden - help with plant selection 16Nov 20, 2010 3:53 pm The council came out some time ago and evened out the tree a little, however in the past couple of weeks it has started looking a bit crook. The leaves have started to dry out and fall off and it looks like the tree is dying. There are some pretty deep scratches on the trunk from where the cats have been using it as a scratching post, is it possible that this is the cause? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ It has been getting plenty of water as we've had a water restriction exemption to get the lawn and garden established. New beginnings. Re: Front garden - help with plant selection 18Nov 21, 2010 7:30 pm Try find them at the moment though, Keen. I told you the tree was stuffed. It is about the roots, not the bark. Cats scratching will do diddley squat. Hi there, we have classic cream gutters, fascia’s, roller door and undercover carport. We are are going to paint the roof a terracotta orange colour. After some… 0 4502 0 4703 Hi Kaiser85, We are building with Firstyle Homes. Our build has just started, slab pour is on Saturday (hopefully!). Their standard range is pretty good. We did our… 1 6482 |
