Browse Forums Kitchen Corner 1 Sep 28, 2010 3:33 pm If you have any questions or queries i would be happy to help Kind Regards David Curtis (Consultant) Info From Benctop Forum: 2Sep 28, 2010 4:25 pm Hi all, business edited out Is another company that provides engineered stone and provides a range that is a little different to the Caesar stone and Essa stone. All the bench tops have there positives and negatives, but the tried and tested laminates are still very common and are the most cost effective. Be careful of the gloss laminates as they have the tenancy to show marks and scratches and while there are a couple of products that will mask the damage you can still notice the difference when looking down the surface. I work as a consultant for a small kitchen company **** based in Tassie, i have noticed a significant trend in the past 12 months towards the engineered stone for not just high end kitchens but throughout the kitchen range. It is becoming quite common to use only a 20mm edge with a highlighted shadow mold (eg: pure white with bright red and gunmetal grey or designer white doors and panels) this is enables the clients to have the quality of the stone at a reduced cost. Depending on the size of the kitchen and the bench top manufacturer the difference between 20mm stone & Laminate can be under $1000. Acrylic bench tops you generally get what you pay for and some of the cheaper options are prone to scratching easily, as a general rule if you go with acrylics i would keep clear of any of the darker colors and generally only go with the the light whites etc. when testing a sample scratch it with a coin or rock and if it marks white i would maybe have another think. This rule applies for the higher end products also. 2pak doors are high maintenance and can chip easily, if you are in the market for 2pak request a door/panel report from you kitchen installer and the reliant codes & brands of paint used when you get your kitchen made. this way if you ever have to replace a door it will save you time and money. Vinyl wrap is a great product and we have been dealing with it for many years, just remember that the vinyl is essentially a plastic and excessive heat from a kettle or any other heat source has been known to de-laminate the material. check when purchasing a kitchen where the doors are manufactured most reputable company's keep warranty stock so you can replace panels if its needed. Some large mainstream (supermarket style suppliers) are known to buy vast quantities of materials from overseas and limited warranty are available for identical panel & door replacement. If you have any questions or queries i would be happy to help. Kind Regards David Curtis In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 7113 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 2591 Thanks for sharing. Looks good. The joiner has come back with a quote of close to 5k. I think we are going to not do it. Attaching panelling is something they are dead… 11 10095 |
