Browse Forums Owner Builder Forum Re: cost of plans 16Dec 28, 2009 2:07 pm Plans Done Feb 2010 Permit Done 23 April. Set out Done. Scrape and Excavations Done. Footings Done May 10th. Now, to find a brickie.Got one! Sub-floor bricks & Garage Done - 13th June Sub-floor installed 28 June (?) Re: cost of plans 18Aug 04, 2010 12:57 pm Form memory, mine were about $1200 (35 square home). I had a sketch ready, and made a few changes along the way. The engineering then cost about $1100, and the 5 star report about $200. Blog is now up - http://www.jbdave.blogspot.com/ Re: cost of plans 19Aug 05, 2010 9:57 am emmyb Hello, We are about to do a reno and need to get plans and permits to knock down a couple of load bearing walls as well as extend the rear deck. Can you tell me what the 1.1k engineer costs entail compared to the 2.2k that you paid for the draftsman? Cheers, Emmy Hi Emmy, the draftsman draws the plans & working drawings showing all dimensions and elevations and then passes those drawings to an Engineer who assesses the structural needs of the house. The Engineer then provides the details for footings, slab, structural beams, retaining walls, etc. These Engineering drawings are read in conjunction too and supercede the working drawings. If the Engineer has specified anything that is different to the Draftsman's drawings the Draftsman will then adjust the working drawings to show the required structural changes. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: cost of plans 20Sep 11, 2010 12:00 am TDS Ours have cost us $2.2k. This includes finished working drawings, submission to approval board (w*nkers), full scope of works, energy rating and soil tests / surveyor. I supplied a prelim sketch, inc room dimensions, of what we wanted, and he 'formalized' and made work anything that was off, which surprisingly there was alot of. He has assisted greatly with the thousand questions us OBs have. FYI the engineering will cost $1100. 400 sq mtr single storey in Melb. Hi guys, great forum, thank for all the contributors making it such a good place to learn... TDS, would you mind passing on the archi's/drafty's details? I am an OB in the planning stages also an have had a couple of quotes around 4-5K area. Thanks very much in advance Really tight at the top of the stairs- how to get furniture into those rooms? Study books - does anyone really use them these days? Large storage closet would be more functional. 2 6895 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 13781 If there have been changes, variations, during construction then the drawings should be revised, the building permit amended and the current, as built drawings given to… 2 4491 |
