Browse Forums Heating, Cooling & Insulation Re: Builder and Evap Cooling they include 3Aug 02, 2009 6:31 pm TheBoatMan Builders usually put quite a large margin on any air conditioning in their homes. I would personally get about 3 of my own quotes so i could compare. Some builders can as much as double the price they get for air conditioning, which means you may end up paying way too much! Yep, exactly what we are doing. Is a decision that needs research and it's no great shakes to install post build Re: Builder and Evap Cooling they include 4Aug 25, 2009 1:51 pm wombat TheBoatMan Builders usually put quite a large margin on any air conditioning in their homes. I would personally get about 3 of my own quotes so i could compare. Some builders can as much as double the price they get for air conditioning, which means you may end up paying way too much! Yep, exactly what we are doing. Is a decision that needs research and it's no great shakes to install post build We are in a simillar situation ,quite happy to fit in our own refridgirated cooling and gas heating now our worry is how can we get our builder to add wiring that will accomodate these to systems so that when the installers come in the wiring is already there Re: Builder and Evap Cooling they include 5Aug 26, 2009 3:27 pm Going to confuse you some more here but central air and heating should also be looked at. Because you use the same heat pump or inverter for both cooling and heating it may be cheaper. Also it is in the roof and all plumbing is in wall and out of site. Obviously the running costs are probably dearer but i find if you don't go excessive temperatures it is very affordable. I find 22 degrees in summer and around 18 in winter quite ok. Looking at that i think 1 of my 2 thermostas in wrong, but that is the settings. Daryl Re: Builder and Evap Cooling they include 6Aug 26, 2009 10:26 pm I just went through the same thing with my parents in law and we waited till the winter special to install ducted evaperative and saved around $1600......might be another option for you. Shop around though as there are many evaperative systems and they are very different in quality. In previous homes I have used Breeze Air and also Aqua Breeze. For our comfort and price we will most likely go the Aqua Breeze route again. Signed with Carlisle - Atlantique 36Mk2 altered & upsized Botanic Ridge Estate - Build started 22nd Oct 2010 Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20426 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 13781 |
