Browse Forums Kitchen Corner Re: powerpoint on waterfall island bench 4May 27, 2009 4:00 pm Building our dream home - H3nley Ascot 384 Painting done - electrical, alarm and tiling being completed!! viewtopic.php?f=31&t=17939 Re: powerpoint on waterfall island bench 5May 28, 2009 11:36 am If we're put on this earth to help others, what are the others here for? Re: powerpoint on waterfall island bench 6May 28, 2009 1:04 pm Building our dream home - H3nley Ascot 384 Painting done - electrical, alarm and tiling being completed!! viewtopic.php?f=31&t=17939 Re: powerpoint on waterfall island bench 8May 28, 2009 4:12 pm If we're put on this earth to help others, what are the others here for? Re: powerpoint on waterfall island bench 11May 29, 2009 10:59 am If we're put on this earth to help others, what are the others here for? Re: powerpoint on waterfall island bench 13May 29, 2009 1:51 pm If we're put on this earth to help others, what are the others here for? Re: powerpoint on waterfall island bench 16May 19, 2011 7:30 am __________________________________________________________________________________________________________________ All new built homes look like display homes... until the furniture goes in. Re: powerpoint on waterfall island bench 19May 19, 2011 2:44 pm How about a pop-up power point?? It would be less noticeable than a traditional outlet. Better still you can mount it on the top of your bench to avoid spoiling the look of your Caesaratone waterfall altogether. I saved the below photos from someone’s thread last year (sorry I can’t remember who and I hope they don’t mind)! They are made by Clipsal and are available in white too- I reckon if you have a white bench like ice snow or similar you would not even notice it if you place a fruit platter or something next to it. If the pop-ups don’t float your boat and you want an outlet on the waterfall itself then the Clipsal Saturns are pretty shmick too and come in slimline black and white- less obvious than a metal finish IMO. Cheers http://i1200.photobucket.com/albums/bb326/inverell/ClipsalPop-upoutlet1.jpg http://i1200.photobucket.com/albums/bb326/inverell/ClipsalPop-upoutlet2.jpg http://i1200.photobucket.com/albums/bb326/inverell/ClipsalPop-upOutletWhite.jpg Re: powerpoint on waterfall island bench 20May 19, 2011 3:25 pm I think that build was Nathan's? The only issue I would have with the pop-ups is that they will impact on whatever is below the benchtop. Ie in some cases you wouldn't be able to have a drawer as there may be a clearance issue. I have a double PP on the "dead" side of my island bench. It is the farthest away side so not seen unless you walk to that end. Both of my ends are 80mm waterfalls and as it was mounted on the side had no impact on the drawers / cupboards on the other side of the waterfalls. Some things are worth waiting for. DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6573 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11632 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31229 |
