Browse Forums Building A New House Re: Does your builder provide you with a key at Lock-Up? 5Mar 07, 2009 7:12 pm 2014 - Prepping to build the Soho 4 with Plantation homes, industrial style 2009 - Built the Brampton with Coral Homes viewtopic.php?f=31&t=15399&start=280 Re: Does your builder provide you with a key at Lock-Up? 18Mar 08, 2009 10:43 am finished building 40 square home on 5 acres with perry homes.working on the landscaping just finished pool deck with ://forum.homeone.com.au/viewtopic.php?f=31&t=2217 Re: Does your builder provide you with a key at Lock-Up? 19Mar 08, 2009 12:20 pm 2014 - Prepping to build the Soho 4 with Plantation homes, industrial style 2009 - Built the Brampton with Coral Homes viewtopic.php?f=31&t=15399&start=280 Re: Does your builder provide you with a key at Lock-Up? 20Mar 08, 2009 2:33 pm coral doesn't seem to have a problem with having other tradies onsite to install air con etc[/quote]
Yes this is true, but you still need to fill out a form they give you in regards to extra tradies going onsite before they allow this. I think mainly for insurance purposes, i suppose. Built a modified "Daydream 279" .. Cor@l Homes on a flat 4473m block!! And lov'n it!!! Your house should come in "as new" condition. It should be clean, and without stains 1 2857 I ran into trouble finding a lock that would fit my particular door, like your situation with your pivot door. I wanted a safe lock that couldn't be messed with easily. 4 25702 1 3403 |
