Browse Forums General Discussion 1 Mar 01, 2009 5:40 pm Hi all.
We are doing a complete reno on our place and have decided to lay bamboo over the existing floor boards. This prompted a debate on 'Should we lay parallel with the existing boards or maybe lay them diagonally to show a little avangarde and accentuate the size of the open plan design'. What say you all?? Cheers, Kaz n Tim. Re: Diagonally layed flooring ?? 2Mar 01, 2009 5:59 pm You shouldn't lay parallel with the existing boards, rather they should lay perpendicular. Diagonal should be fine also. Re: Diagonally layed flooring ?? 3Mar 01, 2009 8:12 pm there are a few pics on this thread of some diagonally laid boards
https://forum.homeone.com.au/viewtopic.php?t=6583 "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: Diagonally layed flooring ?? 4Mar 01, 2009 8:22 pm donuts there are a few pics on this thread of some diagonally laid boards https://forum.homeone.com.au/viewtopic.php?t=6583 Are you on a diet donuts Re: Diagonally layed flooring ?? 5Mar 01, 2009 8:25 pm Yes I am SuH I am so hungry. "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6148 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15839 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6432 |
