Browse Forums Paving & Concreting 1 Feb 04, 2009 11:15 pm As per a previous post we've had some exposed aggregate concrete laid down by a local contractor (Werribee) picked from the local rag...seem to find good tradies in our local paper.
It's behind the garage, what I call the "off side" of the house. Wanted something low maintenance, wouldn't show the dirt (light or dark), big enough for junior to ride around on. Was going down the path of plain concrete because I couldn't justify the expense of what I thought would be horribly expensive exposed agg. Here's the area we wanted done...basically 49 sq.m of drive. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ So Phil came out which his big boomy voice at 6:45 am to do the quote...and this was what he came back with: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ With F72 mesh, saw cut control joints, sealed, yadda yadda. To my mind the $20 per square metre differential in price was a no brainer. Bobcat and tipping was a bit of a rip off but overall the price was OK. Day One (6:45 am) they did the excavation which ended up being surprisingly a lot considering how flat it looks, screenings, forms and set up the drainage along the roller door and at the clothesline into the existing stormwater. Day Two (6:45 am) they poured...note juniors foot prints....argh! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Day Three (6:45 am) they blasted...you cans see the far drainage point near the laundry steps. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And then sealed....sorry haven't taken a photo yet. Here's a close up of the mix (not yet sealed)...it's nothing special...I call it "Phil's Special Mix"...he could do others...this one cost $140 per cubic metre told me where he sources his mix from and if I wanted another I only needed to pay the differential per cubic metre. And it's in non-colored concrete. Gave me an address of where he done this color before and I liked the fact that this mix didn't seem to show as much dirt, wear, or muck as the other exposed drives in the same area. I know it's not some fancy "Sunset Over Uluru on a Midsommer Day" color...it's utilitarian, only we see it, and a good price.... ...horses for courses. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I doubt he works anywhere except the western suburbs so if you're interested PM me...job was good, neat and Phil kept the boys in line. Drainage appears to be working well as well. And yes the 6:45 am starts got a bit old...very quickly.... mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Château TDL: TDL Exposes Himself...well concrete anyway! 2Feb 05, 2009 7:22 am I actually think that's a great mix because it will go with any style/colour of house.
Also, not being too dark, it won't get quite as hot under little feet. Good choice. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Château TDL: TDL Exposes Himself...well concrete anyway! 3Feb 05, 2009 8:35 am to_do_list
I think that's a great mix also, looks fine! For that price, you should be very happy. cheers Chris Re: Château TDL: TDL Exposes Himself...well concrete anyway! 5Feb 05, 2009 9:48 am The color is actually quite cool even on stinking hot days...and DS has already set up the "Fifth Gear Slalom Challenge" for his tricycle.
So far his quickest time is 15.9 seconds around ten blocks of post off cuts... ...yep he's a petrol head...loves Fifth Gear, Top Gear....and truck racing.... mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils. 10 9047 Finally got the Soakwell at my house sucked out. Now I’m looking for ideas on how to hide it as it’s a bit of an eye sore. I’m thinking I’d like to turf over the… 0 3356 |
