Browse Forums Bathrooms and Laundry 1 Dec 24, 2024 10:16 pm Hi all, I’m new to bathroom renovation and need some assistance with who to get in to help with what, and in what order. We are back to bare concrete slab and bare cement sheet walls. First question - does the tiler install the screed layer and do the waterproofing? If not, who does those parts please? Second question - how long after the screed is laid can it be tiled? Third question - what order does everything need to be installed/done in? Is it screed, waterproofing walls and floor, bath/vanity/shower install, tiling, then electrician? Thanks for your help. This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 62007 ![]() Thanks for the reply. Had a look at the suggested lot and found other problem on easement, which i will asked in separate thread. 2 48601 Which application did you filled out ? Gas abolishment form has an option to remove meter or abolish connection. It's 92$ to abolish the gas connection in brisbane 1 18235 |
