Browse Forums Building A New House 1 Oct 29, 2008 6:32 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅
My ensuite is next to one of the minor bedroom I found that the plumbling work they do (prepare for the vanity unit) is sitting in the middle of the wall between the minor bedroom and the ensuite (hope i make sense to everyone), is it ok? or should i be concern? would appreciated any comments, thanks Blog - http://clageonewhouse.blogspot.com/ Building Thread - viewtopic.php?f=31&t=10886&hilit=milan I am in, with my husband and my beautiful bunny Re: Is this ok? or should i be concern? 2Oct 29, 2008 7:49 pm Hi claego, I really have no idea about this stuff but I think you are right to question it. Our plumbing didn't interrupt the framework like that Hopefully someone else will offer a more expert opinion.
Congratulations on the slab and frame by the way Re: Is this ok? or should i be concern? 3Oct 29, 2008 9:41 pm Thanks donuts, they are building quite quick, only half a day and the frame is almost done (except for the roof). i tried to check if there is any broken frame or weid things, but turn out quite good except this plumbing things..
I will properly put up a thread later... But now, i properly need a quick call to my SS... Blog - http://clageonewhouse.blogspot.com/ Building Thread - viewtopic.php?f=31&t=10886&hilit=milan I am in, with my husband and my beautiful bunny Re: Is this ok? or should i be concern? 4Oct 29, 2008 9:44 pm Are your vanities going to be wall hung? by the looks of it , this is why the pipes are coming from the wall. In our last house we had our plumbing like this also. This way you will have a clear floor under the vanity unit and can see no plumbing under the unit.
Hope this helps Built a modified "Daydream 279" .. Cor@l Homes on a flat 4473m block!! And lov'n it!!! Re: Is this ok? or should i be concern? 5Oct 29, 2008 9:59 pm We had exactly the same thing - I had a MAJOR stress out over this, and was eventually told it was OK. After looking through all the other 20 or so houses under construction in the estate one afternoon (yes, I was obsessing big time over it) I discovered at least half of them had the same pipe through the frame thing going on
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Built a Clarendon 'Balmain' 2008 Re: Is this ok? or should i be concern? 6Oct 29, 2008 10:21 pm You may be right seakyl, I don't recall seeing any plumbing work under the vanity unit in the display.. only the main bathroom does... this properly why i only spot this issue in the ensuite, but not the main bathroom.. I have to slap myself twice, when i walked through the displays i did say that this setup is nice.. silly me Maxie, thanks too, and not obsessing at all.. i was thinking the same thing actually.. but there aren't many houses built in my estate so i am thinking to go to another estates.. Blog - http://clageonewhouse.blogspot.com/ Building Thread - viewtopic.php?f=31&t=10886&hilit=milan I am in, with my husband and my beautiful bunny Re: Is this ok? or should i be concern? 7Oct 30, 2008 3:16 pm If the ensuite is the side you took the picture from then there is no problem at all and it is a normal thing so nothing to worry about. Thats a prefab frame so if it took them any longer than a day to put the walls up then they would be considered slow carpenters Re: Is this ok? or should i be concern? 9Oct 31, 2008 3:58 pm Yep, we had that sort of thing - except ours prevented the plaster fromm being hung as it stuck out too far - it had to be jackhammered and moved back , so just make sure it's in the right spot !!!!!!! Solidarity, not solidity.......The Lexicon of Life Re: Is this ok? or should i be concern? 11Nov 02, 2008 7:51 am Hmmm, this really got my attention claego, because after a brief inspection of our frame yesterday, it appears we will have a 'wall hung' toilet!!!
It seems we have a pipe under our frame WTH? We have taken photos and will query this with builder on Mon, but at the moment it seems that someone was a little out with their measurements! And so it begins... Cheers, Dee ---------------------------------------------------------------------------- Our BLOG: http://buildingourdreams.blogspot.com/ Building the 'DEE 257.9' Contract signed 08/09/08. Re: Is this ok? or should i be concern? 12Nov 04, 2008 1:42 pm It is fine but I would toe nail a stud on both those bottom plates to the top plates. Re: Is this ok? or should i be concern? 13Nov 04, 2008 2:24 pm She&He+3+3 Hmmm, this really got my attention claego, because after a brief inspection of our frame yesterday, it appears we will have a 'wall hung' toilet!!! It seems we have a pipe under our frame WTH? We have taken photos and will query this with builder on Mon, but at the moment it seems that someone was a little out with their measurements! And so it begins... Shouldn't be a problem, the plumber will just jack hammer the concrete to alter it and it will be patched up. Re: Is this ok? or should i be concern? 14Nov 09, 2008 3:13 pm Doh!
We have been assured that all is as it should be. Apparantly, this hole is for a breather pipe that will be run up through the wall and out through the roof because the ensuite toilet is not on an external wall. We have also been assured that the pipe for the toilet is there despite not being visible at present, as is the drain pipe for the bath which is also currently invisible. Cheers, Dee ---------------------------------------------------------------------------- Our BLOG: http://buildingourdreams.blogspot.com/ Building the 'DEE 257.9' Contract signed 08/09/08. i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12719 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 15980 |
