Browse Forums Kitchen Appliances Re: Fisher & Paykel E3728 fridge leaks water onto the floor. 3Mar 22, 2023 7:56 am I have watched a video on how to clear the pipe which takes water (condensation?)from the freezer to the pan underneath the fridge but unfortunately it was for a fridge with the freezer at the top. My fridge has the freezer at the bottom. Would I be correct in assuming that I would have to access the tube from behind the freezer at the bottom? The video suggested that the probable cause of the leakage was a blockage in the pipe. There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2452 I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 7530 The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring… 1 3276 |
