Browse Forums General Discussion 1 Feb 05, 2023 8:07 pm Re: Wall mount bracket on single brick wall 4Feb 06, 2023 5:58 pm it will depend on the weight of the bag and the style of the mounting bracket. you'd need to ensure that the weight of the bag, with a kid (or an adult) that decided to hug the bag and hang on it is evenly distributed along the wall, and isn't just going to pull the screws out of the brick. i'd use dynabolts for whatever it is that's going to end up being mounted to the wall itself. If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8818 Hello All π We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 9658 canβt tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 5510 |
