Browse Forums Heating, Cooling & Insulation Re: Ceiling insulation 3Jan 08, 2021 2:59 pm Berek How is the rest of the house insulated? R3 if it’s not, R4 if it is. Insulation suffers from diminishing returns on $ per sq/m. The rest of the house is double brick, so no insulation in the walls. If it’s not insulated anywhere else shouldn’t I aim to get a higher Rvalue for the ceiling? Re: Ceiling insulation 4Jan 08, 2021 5:10 pm Elightly Berek How is the rest of the house insulated? R3 if it’s not, R4 if it is. Insulation suffers from diminishing returns on $ per sq/m. The rest of the house is double brick, so no insulation in the walls. If it’s not insulated anywhere else shouldn’t I aim to get a higher Rvalue for the ceiling? You can do a retrofit wall insulation for your double brick InsulGuard Cavity Shield | Cavity Wall Insulation for New & Existing Homes (insulguardinsulation.com.au) Just waiting on a quote for our house now. Re: Ceiling insulation 5Jan 08, 2021 6:52 pm Imagine you’re sleeping on a mattress in winter. You are cold but only have a $1 tea towel to cover you. Still cold. You have another tea towel but it cost $10. You add that but you still have cold feet. Next one costs $100 and again your feet are still cold. Covering only 1part of your body is like insulating only 1 part of the house. Heat/cold is gained/lost through walls floor and windows. Re: Ceiling insulation 6Jan 09, 2021 10:24 am For Perth, the government's 'Your Home' website recommends a minimum of R4.1 for the roof/ceiling, R2.8 for the walls https://www.yourhome.gov.au/passive-design/insulation Found the answer. The recommended distance is .... 1 6170 Thank you @ashington Homes for your reply! They just got back to me and offered credit for me to just take it as is. It was a less than quotes I got from ceiling… 6 1834 Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11532 |
