Browse Forums General Discussion Re: New neighbours and the eyesore... 5Apr 01, 2013 5:20 am Built the Seaview 36 with Rawson Homes - Read about it on my blog http://lamaisondemorgan.blogspot.com.au/ Re: New neighbours and the eyesore... 15Apr 01, 2013 10:45 pm The outlook in general could really do with some greenery in general. Make sure you think of the long term with your planting strategy. A nice perimeter of plants will create a cosy private haven where you won't need to spend any of your attention on what's outside your property whether it be a neighbours roof or a satellite dish. Re: New neighbours and the eyesore... 16Apr 02, 2013 5:04 am How Hard Can it Be Gee you guys are a tough audience! Cinderella_375, hopefully you can ignore the sly remarks and the questioning of your concern. Fact is - you have to stare at it and you don't like it. humble Wow.. what a over reaction, your neighbours are allowed to do what they want, just get some screening. Humble, for the record - I am not sure if there are any regulations relating to these dishes in particular, but in general - there are many regulations and restrictions on what neighbours can and can't do - either close to boundaries or overlooking neighbouring properties - so it isn't a case of "neighbours are allowed to do what they want" by any means. Back to the question at hand - C_375, as I said, not sure if there are any regulations relating to this kind of thing (you would have to check with your council). But in terms of putting in trees, even with an easement, you should find that planting trees would not be an issue. Again, check with your council, but my understanding is that as long as you are not putting permanent structures (ie swimming pool or building a garage) then you can garden and put semi permanent structures over the easement land. You can even apply to have permanent structures built over easements. So as I said, check with your council, but you should have no problem planting trees. Might take a few years to establish itself, but meanwhile you can use fence screening and or tall screening plants. I'm sure once some garden and greenery and landscaping is present, the dish won't be so glaringly obvious. Just that there is nothing much else to attract the attention at this stage. Good luck. HHCIB Its a satellite dish, the neighbor can do what they want, as long as its in the property. When you can hear your neighbor fart because they are so close to you (2m with 1.8m fence @ 1m) I wouldnt be worried about the dish. I am not sure what sense of entitlement class I missed at school, but your neighbor can put a dish up, he can put a lot of things up, a painted pink pergola, there is nothing you can do. Neighbors are funny things, what they get up to is the least of my concerns. Re: New neighbours and the eyesore... 17Apr 02, 2013 7:45 am Deleting my post.... not worth the effort (or trouble ).
Re: New neighbours and the eyesore... 18Apr 02, 2013 7:47 am Play nice people. Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: New neighbours and the eyesore... 19Apr 02, 2013 8:34 am I'm at fault here - so I might ask the question ... does anyone find solar panels a bit of an eyesore ? Ours are situated so that few can see them - but I've seen them - rows of them - across the front of a house roof and they look awful. A real eyesore. I laughingly said to Mrs SM - well at least ours are on the side we can't see them ... I must admit those huge dishes are a tad OTT. Maybe you need a device to sprinkle little pieces of aluminium wrap on it at a strategic time ... Re: New neighbours and the eyesore... 20Apr 02, 2013 8:47 am SM - no, I personally don't find solar panels to be an eyesore. They are usually in line with the existing roof line - so therefore don't stick out like "you know what" . Plus, they are doing something for the environment so a bit of tolerance needed for those kinds of things. I would find a satellite dish - especially one peering directly over my fence - a bit obtrusive, but that's just my opinion. HHCIB it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7185 The only thing to add to these comments is that where possible it's always good to try and work with people than just say "no" because you can. Having someone… 4 17253 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10396 |
