Browse Forums Heating, Cooling & Insulation Re: Actron Air conditioning ducting ESP Series vs Daikin 11Feb 01, 2013 12:02 pm MR2 I wonder if Choice has ever done a review on the ducted systems (not just split systems) I don't think so. There are so many variations in the install it would make it quite difficult. And I wouldn't be paying too much attention to their reviews of splits either. Re: Actron Air conditioning ducting ESP Series vs Daikin 13Feb 01, 2013 12:42 pm http://forums.whirlpool.net.au/archive/ ... #r21873796 This is leading me to believe your wrong? taken from here: http://forums.whirlpool.net.au/archive/ ... #r21873796 Slooowwwwly getting a Manhatten 35 in Middleton Grange Re: Actron Air conditioning ducting ESP Series vs Daikin 14Feb 01, 2013 12:43 pm and this here contains interesting info... http://www.airah.org.au/imis15_prod/Con ... 011-AS.pdf Slooowwwwly getting a Manhatten 35 in Middleton Grange Re: Actron Air conditioning ducting ESP Series vs Daikin 15Feb 15, 2013 10:12 am Hey Not sure about Icemans point was about the ActronAir product Quote "There are many very good reasons for purchasing an Actron but the supposed efficiency is not one of them Well ActronAir claims they can save up to 60% against a std system with their ESP Plus products Its in writing on their brochures and has been for years http://www.actronair.com.au/UserFiles/A ... 20-%20LR(2).pdf The ACCC protects consumers with regards to this sort of stuff Actron even won an award for the product at ARBS the Air Conditioning, Refrigeration and Building Services industry show for environmental/ innovative product of the year So As far as I can tell energy efficiency actually is a reason Also Aussie, local network of dealers, service support and 30 years in business Not sure what the Imported Daikins LG Fujitsu and such are claiming that they want to put in writing How much can they save percentage wise? Anyone seen anything? Re: Actron Air conditioning ducting ESP Series vs Daikin 16Feb 15, 2013 1:11 pm We have a SRD 230c unit. it was installed in our new build. We have used the heating function but only a small amount. Heated the house (approx 350sqm)without a problem. During summer with the weather the way it's been, it has cooled what I think pretty effortlessly, as the airflow reduces almost to the point you cannot feel it for lengthy periods. Basically it works so well we keep increasing the temp as it starts so that you start to feel to cold. As for noise, we cannot hear the unit inside. Outside the only noise you hear is the fans running, which certainly isn't loud and the noise the switches make cutting the fans in and out. It probably could be described as a clunk, but again it is not that loud. We're waiting on the official power bill but an enquiry has found that it is dearer than an evaporative system, surprise, but cools a LOT better, but has not cost the earth and has been used every day in the billing period. We had teething problems, but that was installation related, not the unit's fault. At this point in time I am more than happy with the unit. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Actron Air conditioning ducting ESP Series vs Daikin 17Feb 15, 2013 1:49 pm jethro68 ActronAir claims they can save up to 60% against a std system with their ESP Plus products Its in writing on their brochures and has been for years http://www.actronair.com.au/UserFiles/A ... 20-%20LR(2).pdf This is a huge red herring. There are so many variables in there it's not funny. jethro68 Hey Not sure about Icemans point was about the ActronAir product If you read what I said at the bottom you'd see... Lots of good reasons to buy an Actron but supposed energy efficiency isn't one of them. At the end of the day you just have to step back and have a serious look. If this digital scroll was so good do you really think no other manufacturer would be using it? Re: Actron Air conditioning ducting ESP Series vs Daikin 18Feb 15, 2013 1:58 pm we would be a lot more convinced if you had any reputable independent tests showing how it does/doesn't work against other systems showing actual system usage etc, I don't mean this in a nasty way just that I bet that how most people reading this are viewing it.. I have a question... is it possible to get all the wiring and ducting done and then install the units later? how would the aircon guys install the unit in the roof after the house is finished? just cut a huge hole in the roof? Slooowwwwly getting a Manhatten 35 in Middleton Grange Re: Actron Air conditioning ducting ESP Series vs Daikin 20Feb 15, 2013 2:23 pm honestly I would not accept data provided directly by Actron as independant, I'd love to see a choice report on it or something, I actually trust them! if we can squeeze in the upgrade I might actually throw a clamp meter around mine and see what it says, that's 12 months off though. Slooowwwwly getting a Manhatten 35 in Middleton Grange Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 8986 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8207 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5907 |
