Browse Forums Building A New House Re: LOOSE LAY KARNDEAN - update from old thread 110Jan 10, 2013 5:53 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: LOOSE LAY KARNDEAN - update from old thread 114Jan 14, 2013 3:25 pm Hi Mazz, the looselay Karndean is actually recommended specifically with floor boards in mind. I can pm you a phone number of a guy you might be able to talk to for some good old fashioned advise. He sells everything under sun from timber, to laminates, to vinyl so he doesnt have an 'agenda'. Cheers Re: LOOSE LAY KARNDEAN - update from old thread 115Jan 15, 2013 12:55 pm Serialbuilder Hi Mazz, the looselay Karndean is actually recommended specifically with floor boards in mind. I can pm you a phone number of a guy you might be able to talk to for some good old fashioned advise. He sells everything under sun from timber, to laminates, to vinyl so he doesnt have an 'agenda'. Cheers Thanks Sb, will keep that in mind, we are hoping to get away in the next few months (it's 400km one way to our nearest major centre) and I aim to have a look at some flooring places, ordering via an online pic is a bit overated!! I know the house is old, but I still have to like the floors!! Thanks leanne yes i love the pics you posted... i might have drooled a bit cheers Maz Re: LOOSE LAY KARNDEAN - update from old thread 116Jan 15, 2013 1:05 pm Oneness: any news on the colouring? Re: LOOSE LAY KARNDEAN - update from old thread 117Jan 18, 2013 8:46 pm Fmac...My apologies I have only just seen your post... Received the planks on tuesday (5 of them to give us a good idea) and they are not the same as the display boards, however, having said that they are also not as orangey as the previous sample sent to me. Sooo we have decided to stick with them ... The GM at Karndean has set enough aside to cover our job from the same batch as the ones he sent us, so we know exactly what colour they will be...All is good and we are quite relieved that we dont need to start rethinking everything... I cannot commend Karndean highly enough for the customer service they have given...totally first class all the way... I am sure if you were happy with the Classic Oak sample you had already been sent then you will be just fine...no panic needed... phillipperak007 - You only need to post once in the relevant thread...This thread is regarding vinyl planks... Slab Poured 30/05/12 Lower Floor Plate High 20/08/12 Upper Floor & Wall Framing 30/08/12 Roof 14/09/12 Lock-Up 13/12/12 Yee haaaaa WE ARE IN & I HAVE A NEW IPHONE Re: LOOSE LAY KARNDEAN - update from old thread 119Jan 21, 2013 11:31 am Can I just say, totally awesome that I requested sample colours from kardean and they sent an entire looselay plank!! Impressed much, previously I've recieved cut offs or squares!! Nice Re: LOOSE LAY KARNDEAN - update from old thread 120Jan 21, 2013 2:09 pm Karndean is WA also? I should prob just research myself but will forget by tonight when I have time haha A Sabco spin mop, minimal moisture, not very regularly. I was told these hybrids are water resistant 🤷♀️ 2 7634 Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 11109 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 |
