Browse Forums Home Theatre & Automation 1 Aug 23, 2008 4:28 pm Hey boys
I went out to the display today and managed to get the measurement for where we want the plasma to sit on on of our walls. The other plasmas will be wall mounted but I am going to get the tv point and powerpoint and normal floor height and just hide them behind tv units etc This is the only TV that is going to be wall mounted without anything to cover the powerpoints with and I really want the look of it floating on the wall with cords/powerpoints hidden. I measured today and I want the centre of the TV (42 inch) at approximately 1.6m from the floor. If this is the case what height/position would you suggest I have the powerpoint and TV point so that it can be hidden....I don't want the TV popping out heaps off the wall either - I'd prefer it as flush as possible. Any help would be great My karma ran over your dogma Re: One last time ;) 2Aug 23, 2008 4:36 pm I forgot to add - the wall that we are mounting the TV on backs onto DD's bedrooms so would it be possible to put the PP and TV point at normal height on the wall in her room?
She will have a desk that would hide the cords too, so this wouldn't be a problem. Or would the Tv powercord etc not be able to reach this far through the wall and down to the powerpoint in her room?? My karma ran over your dogma Re: One last time ;) 3Aug 23, 2008 4:40 pm your best bet would be to get a photocopy of the TV maual showing the rear of the plasma, then you could have the builder "recess" the power point and aerial point to suit...... keep in mind the wall bracket to mount the TV.... you don't want that clashing where you have put the recess.....
the reason I say recess, is so the TV remains flush with the wall because of the plug thickness..... whoever you buy the TV from should be able to confirm if this is required. Gweluphome hubby Re: One last time ;) 4Aug 23, 2008 4:46 pm That is a great suggestion. I never thought of that, not even sure if PD will do it or where exactly to locate it though...we don't have the TV picked yet, it will most likely be a Samsung 42inch.. My karma ran over your dogma Re: One last time ;) 5Aug 23, 2008 4:51 pm Have a chat with the TV people first.... they should be able to help you out before you go talking to the builder about the recess....
You will probably find the builder has been asked this before and may be able to help you out.... Re: One last time ;) 6Aug 23, 2008 6:40 pm If the wall the TV is being mounted on is a single stud thick interior wall then recessing the points won't be that easy.
Putting the points in the room behind the TV is fine - no more or less difficult to work with that way. Don't worry about the exact distance as whoever mounts the TV and runs the cables inside the wall will have long enough cables for the job. Just, if you can, make sure the noggin between the back of the TV and the points has one or more holes in it big enough to at least get the smaller end of a power cord through (same type of power cord as a PC). Basically a hole as big as a 50c piece is plenty (two holes that size are even better ). Be aware of any stud the cables/cords need to cross over (hopefully you can set it up to avoid this). Re: One last time ;) 7Aug 23, 2008 7:52 pm Thanks Rodda - as long as PD agree - you are my man
Alright so I think I will put in in my Daughters room - it just seems easier...I thought the cables would be long enough but I thought that perhaps the powercord that comes with tv might be shorter, or did you mean you can change this too...?? The wall between the rooms is only one stud thick With the holes in the noggin, do I ask the chippies/builders to do this or is it something I can domyself when on site? Finally, once all the plaster is up and the builders are finished and it comes to mounting the TV on the wall, is it easy to thread the TV powerpoint and Tv point through the wall and into DD's room, or will we need to put holes in the wall?? My karma ran over your dogma Re: One last time ;) 8Aug 24, 2008 9:30 am I have longer power cords for devices like plasmas etc.
The holes in the noggins you can do yourself (at least you know it gets done) and it can be done as soon as the frame is up - no waiting for lockup etc. Use a 'spade' drill bit, say a 28mm or 32mm one, I find those the easiest (over a hole saw or an auger bit). We do just put the cords and cables into the wall while installng the TV, and we also make the holes in the plaster at that time (not before). Ciao. Re: One last time ;) 9Aug 24, 2008 11:35 am Awesome thanks Rod
I have my tender appointment on Tuesday - so I'll ask to have the TV point and Powerpoint in DD's room - at normal height. I'll make sure we put the holes in the noggins too So your saying when you make the holes in the plaster when you are installing the TV - which is after handover of the home from PD I'm assuming? If this is so, am I left with big holes in my walls or is it easier to cover up?? I'm just a bit confused on this point Sorry Rod - but I'm a woman remember My karma ran over your dogma Re: One last time ;) 10Aug 24, 2008 12:06 pm No worries.
I make the holes after hand-over and I cover them with things like this: http://www.radioparts.com.au/ProdView.a ... +S-VIDEO+F Very common on rendered homes Smaller suppliers get the lower quality raw materials 6 11892 4 14411 That is a really good attitude Akin to you catch more flies with honey than vinegar. I do enjoy watching that tik tok inspector from Victoria but he does go a little… 12 81991 |
