Browse Forums Heating, Cooling & Insulation 1 Dec 31, 2012 3:06 pm Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Insulation batts in walls? 3Jan 01, 2013 11:23 am Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Insulation batts in walls? 5Jan 01, 2013 9:44 pm Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Insulation batts in walls? 7Jan 04, 2013 11:36 am Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Insulation batts in walls? 8Jan 04, 2013 12:23 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Insulation batts in walls? 9Jan 04, 2013 4:05 pm Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Insulation batts in walls? 10Jan 04, 2013 4:38 pm Wall batts will make a huge difference to your house-for a relatively inexpensive investment and are something that are a nightmare to try and retrofit! Resale is better for a well insulated home too-most buyers these days are au fait with the added heating costs of a poorly insulated home-even if you don't plan to sell in the short term. Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Insulation batts in walls? 11Jan 14, 2013 10:03 am Make sure the foil insulation is reflective outwards with an antiglare surface. Because its such a small area, you might want to consider a high density acoustic wall batt no more than 90mm thick, to maximise Total system R value Found the answer. The recommended distance is .... 1 5957 I am saying that double brick has similar thermal performance due to thermal mass effect. It will be still very interesting to see the state of your framing after 10-15… 10 29741 |
