Browse Forums Heating, Cooling & Insulation 1 Dec 31, 2012 4:06 pm Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Insulation batts in walls? 3Jan 01, 2013 12:23 pm Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Insulation batts in walls? 5Jan 01, 2013 10:44 pm Hi Vess. Our walls will be insulated by that foil stuff as standard by our builder. We wanted to add additional batts in the west facing walls (bedrooms). My brother did this with his place years ago and his rooms are much cooler in summer. He couldn't remember which batts he used so I thought I'd ask here For the cost I think it would be worth it. I figure we can't have too much insulation Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Insulation batts in walls? 7Jan 04, 2013 12:36 pm I thought that all new builds in Victoria had wall batts plus sisilation these days? Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Insulation batts in walls? 8Jan 04, 2013 1:23 pm Just make sure you have your builder's permission to come on site and do the insulation. If you are lucky he will allow it (I would not). Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Insulation batts in walls? 9Jan 04, 2013 5:05 pm Stewie D Why aren't you installing wall insulation to the whole house and not just the West walls ? Melbourne has some pretty cold winters. Stewie Cold doesn't bother us, it's the heat we are wanting to keep out. Especially the bedrooms. The other rooms will be fine as they face south and east. Deemaree I thought that all new builds in Victoria had wall batts plus sisilation these days? I don't think so. I think it's more to do with the R rating and ensuring the 5 (or is it 6 now?) star energy rating. I could be wrong though. building-expert Just make sure you have your builder's permission to come on site and do the insulation. If you are lucky he will allow it (I would not). Our builder is pretty laid back. Said we can essentially do what we want during the build providing he knows what is going on. My brother did this with his build (prob 6 or 7 years ago now) and the difference is outstanding definitely worth doing - for us anyway. Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Insulation batts in walls? 10Jan 04, 2013 5:38 pm Wall batts will make a huge difference to your house-for a relatively inexpensive investment and are something that are a nightmare to try and retrofit! Resale is better for a well insulated home too-most buyers these days are au fait with the added heating costs of a poorly insulated home-even if you don't plan to sell in the short term. Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Insulation batts in walls? 11Jan 14, 2013 11:03 am Make sure the foil insulation is reflective outwards with an antiglare surface. Because its such a small area, you might want to consider a high density acoustic wall batt no more than 90mm thick, to maximise Total system R value Found the answer. The recommended distance is .... 1 4578 I am saying that double brick has similar thermal performance due to thermal mass effect. It will be still very interesting to see the state of your framing after 10-15… 10 23062 |
