Browse Forums Eco Living Re: Does our house comply with the energy rating? 3Dec 10, 2012 8:46 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Does our house comply with the energy rating? 5Dec 10, 2012 9:29 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Does our house comply with the energy rating? 8Dec 22, 2012 10:38 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Does our house comply with the energy rating? 10Dec 23, 2012 7:41 am I rang the Building Commission about this and they said that the house does not comply. But then she pointed me to a document on their website here: http://www.buildingcommission.com.au/re ... 011_55.pdf which says: "As an alternative to the installation of rainwater tanks an RBS may consider the use of Grey water treatment systems or Dual water reticulation and water recycling systems connected to toilet flushing systems as an approach to approve a 6 Star rated house design." Our situation could attract an exemption therefore but it should have all been passed by the Building Surveyor and approved. With the present system they just rely on whatever certificates the builder and plumber supply being correct. And in our case it wasn't. But I'm not going to bother about anything now. Trouble for nothing and another lesson learnt. Re: Does our house comply with the energy rating? 11Dec 23, 2012 10:19 am So... The Building Commission has a recycled water alternative to a rain water tank that they may consider to meet a plumbing regulatory requirement for the 6 star rating. I can only assume that the designer didn't inform you of this. It is not publicised by the PIC or the DSE. How is the purchaser expected to know these things? A major viability of installing a tank is to use the water for sanitary flushing. It seems that you do not have this choice, instead, you have to pay for recycled water. You should have been informed by your designer as clearly you were of the belief (and understandably so) that the inclusion of the tank was necessary for 6 star compliance. Had you known this, then you may have opted for a solar HWS given that you have to (I assume) pay for recycled water. EDIT: Many builders in Victoria do not follow a manufacturers recommendation re the type and size of solar hot water systems best suited to different regions. This has resulted in the installation of cheap underperforming and unsuitable solar hot water services. It should also be noted that the need for builders to follow a manufacturer's recommendation has now been struck out of the National Construction Code. https://www.theage.com.au/national/vict ... x3dfd.html 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Does our house comply with the energy rating? 12Dec 23, 2012 2:04 pm Yes, we do have to pay for recycled water. The building designer didn't do any of the in-depth site research she was supposed to do. Really her philosophy I now realise was least effort for most gain and just do it and hope. Never mind. I've learnt a lot. thanks guys! yes this is how I've exactly raised it with the builder. still awaiting response. 12 6044 10 years ago was a different software than we use now. it has had a lot of changes over the past years. Improvments to the software and changes to how Nathers models need… 8 1459 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110567 |
