Browse Forums Eco Living 1 Dec 08, 2012 1:19 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Watertank Mains Water Switching Devices; Are They Necess 2Dec 08, 2012 7:10 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Watertank Mains Water Switching Devices; Are They Necess 5Dec 08, 2012 8:22 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Watertank Mains Water Switching Devices; Are They Necess 6Dec 08, 2012 9:15 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Watertank Mains Water Switching Devices; Are They Necess 7Dec 08, 2012 9:43 am Save H20, Hmm for my situation. New house, 3 toilets and single water pipe supply to each. Is there any way I can get away with using a single one way separate valve near the tank so I can get away with a normal garden pump? I'll also take your advice and use a round tank instead of slimline. Thanks John Re: Watertank Mains Water Switching Devices; Are They Necess 8Dec 08, 2012 10:57 am Hi John, I just read through your other replies on the other thread and see that you have an upstairs toilet. If your plumber was going to use a mains switching device, then the mains line would be plumbed to all three toilets as you say. You have two other options. 1. Install a manual change over valve (interchange device) instead of the automatic mains switching device. This would require you to go outside to manually change over but most people with tanks are aware of how much water is in storage plus many also develop an awareness of dry spells and an interest in checking the BOM radar. 2. Install a tank top up device. These are simple and cheaper. http://www.apexvalves.co.nz/plumbing/apex/rainaid.html These are usually about $120 and do not require power. There are others available that require a power point. I have seen mains switching devices fail and there are threads on Whirlpool and other forums where people have had expensive problems. They also limit your choice of pumps. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Watertank Mains Water Switching Devices; Are They Necess 9Dec 08, 2012 3:12 pm Hi, the tank top up device looks interesting, but would either option allow me to pass the regulations (of which I know little about) for a new house. I.e. can I achieve Certificate of Occupancy with the tank top up or manual change over? I would prefer it to the more expensive and complicated pump with auto switch device. Re: Watertank Mains Water Switching Devices; Are They Necess 10Dec 08, 2012 4:52 pm JB1 can I achieve Certificate of Occupancy with the tank top up or manual change over? You are in Victoria and the manual change over is ok as per the Plumbing Code of Australia (PCA) 2008 which state... Requirements where rainwater used for sanitary flushing. (1) If a reticulated water supply from a network utility operator is connected, or proposed to be connected to a building where a rainwater tank is installed for the purpose of sanitary flushing, an automatic or manual interchange device that allows alternate use of water from the rainwater tank or the reticulated water supply must be installed to ensure that there is a continual supply of water for sanitary flushing. A top up device is classified as an automatic device and it supplies a limited amount of water (100 mm ) to the tank when the tank's water level reaches a critical low point. See earlier RainAid link. A top up device does not isolate the pump like an automatic mains water switching device like a Rainbank or WaterSwitch does. Water is still pumped from the tank to the toilet. A manual change over device like the MainRain is simply a valve that is manually opened or closed to alternate supply between mains water and rainwater. Manually switching from rainwater to mains water isolates the pump from the cistern(s). Plumbing regulations require check valves to be fitted when rainwater is plumbed into a mains water pipe to prevent cross contamination with rainwater and mains water. Naturally, this applies to both manual and automatic switching devices. While it is often cheaper and neater to install a top up device rather than an automatic switching device, it is still best to isolate the pump and switch to mains water during a long dry period rather than pump water that is delivered to the property under mains pressure. When automatic switching devices fail, they can cost several hundred dollars (plus labour costs) to replace. The Acquasaver is an automatic mains water switching device that is unpowered as it operates by hydraulic pressure. It is also tough and reliable. Note that it is not compliant for potable use. http://www.acquasaver.com.au/ Plumbing a separate water pipe from the pump to separate toilet cistern valves qualifies as a manual mains water switching device as the mains water supply and rainwater supply to the cisterns both have small isolating valves fitted to the toilet walls. It is a very neat, trouble free and inexpensive way to supply the cisterns. The cistern valves also provide an air gap. See diagram in the link (also previously linked) below. http://www.vba.vic.gov.au/__data/assets ... sterns.pdf Plumbing a separate rainwater PEX pipe that branches off to all toilets is easy during the early building stage. If plumbing rainwater into a mains pipe, it must be remembered that rainwater is naturally acidic. As such, it can react with copper pipe. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Watertank Mains Water Switching Devices; Are They Necess 11Dec 10, 2012 11:42 am Hi John/JB1, I have received the following written advice from the Rain Aid's Australian distributor... "The RainAid RA2L complies with the Victorian regulations for use as an automatic switching device and is used extensively throughout Victoria for this application". 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Watertank Mains Water Switching Devices; Are They Necess 13Dec 10, 2012 2:23 pm The Rain Aid comes in two variations and there is plenty of information and diagrams online. The G Store at 1095 Dandenong Rd., East Malvern might be close to you and they have them for $130. The website doesn't say if this is for either model and so I assume that you have a choice. The 2 litres per minute one seems to be the biggest seller but this probably comes back to Sydney Water regulations. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Watertank Mains Water Switching Devices; Are They Necess 15Dec 11, 2012 3:46 pm JB1 They were recommending an Italian made unit for ~$700 previously. I assume that you will be using the water for something more than solely for sanitary flushing given that the 95 sq m roof area you intend harvesting (stated in another thread) will harvest approximately 55,000 litres per annum after roof evaporation losses etc. You generally allow about 8,300 litres per person per annum for sanitary flushing. If you also plumb the pump to a dedicated rainwater garden tap, it is best to use a large diameter pipe to reduce friction loss. I have seen small diameter copper pipe that has been used by plumbers and cringe. Copper pipe should never be used anyway as rainwater is naturally acidic. For garden watering, you are better off to buy an 18 mm garden hose and attach a short length (maybe 1.5 metres) of 12 mm garden hose to the end so that you can use the standard 12 mm hose fittings. You join the two hoses by using a poly 18-12 mm reducer and two s/s worm clamps. At 20 litres per minute, the 18 mm hose has 8 times less friction loss. One of my clients was recently sold a pump for $1,200 by a plumber because my client wanted to water the garden as well as supply the cistern. All he needed was a $250 pump and an 18 mm hose! For anyone who is reading this that is considering harvesting rainwater to supply a cistern only, you only need a small pump as cisterns fill slowly. As pumps operate with lower pressure than mains water but the cistern valve seal is designed for mains pressure, the flow path efficiency can be improved and life made easier for the pump if the seal is replaced with a low pressure seal. To do this, you... Buy a Fluidmaster 400UK063 cistern valve (about $20). Buy an optional very low pressure gravity fed seal 242LP071 (about $2.50 - $3.00). Remove the 'pigs tail' flow restrictor from the bottom of the valve shaft (use needle nose pliars and pull out - it is plastic). Remove the standard seal and replace with the 242LP071 seal. Be very careful to hold the float arm up when you twist the cap. Fit the Fluidmaster to the cistern (you only do up one plastic nut). 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. if it's the look that you're not happy with, the easiest option would probably be to spray paint it all into the same color as the walls so it blends in. there might not… 3 4239 Currently renovating, and our main lounge is 5m x 10m, with a cathedral roof peaking at 6.5m high. Currently have tiles on concrete slab. Room is very hard to heat. I am… 0 5060 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 14490 |
