Browse Forums Landscape & Garden Design Re: Building up a terrace 2Dec 04, 2012 3:31 pm It sounds Like you are building a retaining wall which is a lot more complicated than just putting slabs on edge. Have a look at this link: http://www.anewhouse.com.au/?p=1585 The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Building up a terrace 3Dec 06, 2012 9:18 pm The wall isn't really going to be that high - it is perhaps 15 cm at the moment and I wanted to add another 20 cm on top of this. Would bondcrete help to bind the two slabs together or would this not be sufficient? Re: Building up a terrace 4Dec 07, 2012 4:49 am D101 The wall isn't really going to be that high - it is perhaps 15 cm at the moment and I wanted to add another 20 cm on top of this. Would bondcrete help to bind the two slabs together or would this not be sufficient? No bonddcrete won't make any difference, the pressure only a small wall can develop is considerable. The only reason councils aren't interested in smaller walls is because nobody is hurt when they fall over. I see plenty of brick walls 3-400mm high that are falling over every day at work. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Thanks for your reply. I will just wait and see I guess. Trying to get some more information from our builder. 9 30235 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110524 |
