Browse Forums Heating, Cooling & Insulation Re: Brivis Controller problems 8Nov 26, 2012 1:50 am Hi, OK I can live with the temp indicator readout differences, but the evap cooler problem where the fan speeds up when you turn it down and down when you turn it up is still there........any ideas as to what this entails to fixit? Ian. Re: Brivis Controller problems 9Jul 25, 2014 8:05 pm Hi all, the answer to the problem....all the problems including the fan speeding up was solved when the unit failed completely Jan 2014, middle of the hottest day on record........the technician fitted a new fan motor and a new circuit board......about $600 worth of work. Ian. I am not a brick expert, but rendering would be 1 option, it would be costly to do the entire house though.... 2 6706 Hi all, has anyone been ask to do the weeds in their property while in the middle of build? We are under the impression that they are in control of the site while they… 0 3101 Have had a few issues with out recently done bathroom floor. Probably around 18 months old First there has been been a crack running through a grout line which I put… 0 2184 |
