Browse Forums Bathrooms and Laundry 1 Nov 18, 2012 4:00 pm How long does a normal bathroom renovation take? Can you provide approximations for both big and small bathrooms? Will much appreciate your opinions.. Re: Bathroom Renovation.... 2Nov 18, 2012 4:46 pm It would depend on a lot of factors. Like the size of job more than size of bathroom, how organized you and your tradies are. If you're just replacing tiles and fixtures without plumbing. You do it in a few days. On day to remove existing tiles and fixtures. A day (probably less to paint) another day or 2 (depending on size) to tile. Then a day to install cabinets and fixtures. Thats my estimate on how long each job would take so if you have all trades organized one after the other you can do it pretty quick. Building Henley Monaco Nouveau Q1 - Mernda Villages https://forum.homeone.com.au/viewtopic.php?f=31&t=57810 http://razbuild.blogspot.com.au/ Re: Bathroom Renovation.... 3Nov 18, 2012 6:14 pm Longer than you think. When we do renos we rip out the bathroom on the first day. So Day 1 ripout, jackhammer up floortiles etc. Day 2- plumbing if needed to move,regyprock if needed/ Set bath, Day3 waterproof Day 4 second coat waterproof Day 5 tiles (all or floor) then wall Day 6 grout Day 7- put in shower, toilet, vanity. Nothing quick about it if it's a full reno. That's if you can get the tradies to come on consecutive days. Re: Bathroom Renovation.... 4Nov 19, 2012 7:16 am You need to allow atleast 2 weeks for a full reno. It can take longer depending on the site, materials and whats uncovered when the old bathroom is stripped out. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Bathroom Renovation.... 5Nov 20, 2012 5:56 pm Dang! It will take that long? 2weeks for a full renovation.. About 5-7 days for a small renovation.. Thank you for all the response.. Re: Bathroom Renovation.... 6Nov 20, 2012 7:30 pm We've done two bathroom rennos, same room but different things. First one: Day 1- pull down walls and ceiling, remove bath and shower, pull up floor 2- fix plumbing, redo floors, plaster walls and ceiling 3- stop up plaster, undercoat, waterproof, lay linoleum floor, install vanity 4- install freestanding shower unit, paint, paint again Second time: 1- remove shower unit, build bath frame 2- fix plumbing, replaster wall that had to be pulled apart, waterproof 3- install bath, install tapwear (shower over bath) tile walls and bath 4- fit shower screen - MrsT Brought first house in 2008. Renovated...a LOT. Built in 2013. Our thread: viewtopic.php?f=31&t=67954 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10657 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 13590 Hello Josh, This is Irving from PRIMA, we are a manufacturer of the staircase, railings, kitchen cabinets, windows, doors from China. If you have requirement to purchase… 0 5768 |
