Browse Forums Heating, Cooling & Insulation Re: Brivis Buffalo 85 Blowing Cold Air 9Apr 26, 2012 10:49 pm @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 10091 Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio… 0 862 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 4025 |
