Browse Forums Outdoor Living Re: Can u deck over existing concrete slab? 34Jan 23, 2015 7:23 am Stormy We completed ours today. The whole process (DIY) took 6 weekends, and was very tricky in places, but saved us heaps of money on getting a man in! We used wide plank no nail decking boards and screwed the 'Deck Ties' into joists which were bolted to the slab. Our biggests 'issues' arose as the slab was far from completely level, and many of the boards and joists were bowed making it very challenging. Not something we would do ourselves in a hurry again, but once it's stained and has all the furniture on it, no one will ever know there are a few things that are not quite right! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I would highly recommened that you don't build a deck this way. Joists sitting directly on the ground/concrete, even if covered with an alfresco roof, will mean they are exposed to sitting water when rain blows in. The joists will eventually rot, probably in less than 10 years. Joists should be elevated to allow ventilation and avoid pooling water, there are products you can use to do this. Also I really hope Stormy used H4 treated joists as anything less (H3), will rot out quite quickly. Even H4 wont last for ever hence why timbers should always be off ground. Build Thread: viewtopic.php?f=31&t=57639 Re: Can u deck over existing concrete slab? 35Mar 10, 2015 1:52 pm Hi Plucka. I am currently working on a decking on our alfresco. Much similar to how Stormy did it, joist sitting on the concrete. Fortunately, I haven't progressed that far. I get your point that joists should be elevated. What can I use to achieve this? Can you please give me an idea, say if I go to bunnings, of what to look for? An easy fix that I can think of is have joists sit on paver bricks then use an angle bracet to fasten the joist to the concrete slab. I'll be in trouble though if these paver bricks either break or move. What are concrete packers? Another point is that there will be spaces between planks, where food and other little rubbish can fall through (I am going for 3mm). Has anyone come up with a solution for this, eg putting compound of some sort on the gap (just like a sealant)? Any help would be greatly appreciated. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Can u deck over existing concrete slab? 36Mar 10, 2015 3:45 pm http://www.klevaklip.com.au/How-to-buil ... crete-slab I haven't used this but saw something similar at my local building supply store recently. Also makes it really easy to get it all level regardless of the condition of your slab. http://camdenbuild.blogspot.com.au/ by invite only please pm me Re: Can u deck over existing concrete slab? 37Mar 10, 2015 9:03 pm Those diy decks look great, and that kleva klip looks like a great idea. Part of our building package has a deck on the alfresco, but we are thinking we would like something in the front entrance way very similar so will be watching this thread with interest. Re: Can u deck over existing concrete slab? 38Mar 11, 2015 8:32 am Thanks Robbie and Plucka. That Klevaklip looks like a solution - clever! Hope Bunnings or Masters have them. Re: Can u deck over existing concrete slab? 39Feb 08, 2019 12:30 pm We want to deck over our alfresco slab which is relatively flat but also extend out over a concrete path which has a small slope to allow water run off. Is it possible to deck this and keep it all level? Re: Can u deck over existing concrete slab? 40Feb 12, 2019 11:13 am Novicehandyman We want to deck over our alfresco slab which is relatively flat but also extend out over a concrete path which has a small slope to allow water run off. Is it possible to deck this and keep it all level? From the sounds of your requirement, theKlevaklip (refer video -> www.klevaklip.com.au/How-to-build-a-dec ... crete-slab ) should be the solution to raise and level the deck. Blog @ The Desire One corner of my shed slab will be directly over a 1400mm diameter concrete soakwell. Is it feasible to fill the soakwell with concrete then lay the shed slab over the… 0 674 Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather… 12 6262 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5741 |
