Browse Forums Heating, Cooling & Insulation Re: Brivis Buffalo 85 Blowing Cold Air 9Apr 26, 2012 9:49 pm @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: Brivis Buffalo 85 Blowing Cold Air 10Nov 10, 2012 10:59 am Ours was blowing cold air too.. Turned out to be as simple as the pilot light had gone out. Problem now is that when I follow the instructions to light it, as soon as I release my finger, it goes out. I've tried holding it down for we'll over a minute, but no good. Anyone got any ideas why it's not staying alight? Re: Brivis Buffalo 85 Blowing Cold Air 11Nov 10, 2012 10:49 pm Moezal Ours was blowing cold air too.. Turned out to be as simple as the pilot light had gone out. Problem now is that when I follow the instructions to light it, as soon as I release my finger, it goes out. I've tried holding it down for we'll over a minute, but no good. Anyone got any ideas why it's not staying alight? Pilot light not staying lit is most often cause by the thermocouple. Thermocouples don't last forever and they do die over time. They are a cheap and easy fix, just get yourself a plumber to install a new one. jfm I have since replaced the gas valve with success! The unit was therefore sending the correct message to the gas valve from the thermostat & the main electronic unit within the heater. The gas valve has 2 solenoids, one to allow gas through & one to shut off the gas as a safety. (Or that is what I believe happens) I presume one of them was faulty. I have learnt a fair bit from this repair, so if you have a similar problem, I may have the answer & am happy to help with advice. Yep Gas valves do poop themselves, they aren't a common thing that dies, but they do. And yeah leave all gas appliances to the experts. I am a registered Plumber, and i have the utmost respect for gas appliances. They can be VERY dangerous if you don't know what you are doing. Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio… 0 3636 They should be run in the frame, when run on the outside the pipes breach the cavity clearance. Most times the brickies mortar will drop on them and dry creating a… 1 1077 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 |
