Browse Forums Landscape & Garden Design Re: Build Thread - Modern Formal Garden on a Budget 23Nov 09, 2012 1:29 pm Very nicely done. Re plants: Aumanns on Plenty Rd have good quality plants, but stock varies. They may be able to order in whatever you want if they don't have it though. The big green shed (you know who I mean) is sometimes cheap, but plants tend to be pot-bound (especially the larger ones) and not well looked after. Sertel's at Doreen offer good prices, but again, you need to choose carefully as some plants have been in their pots a long time. I've not had any problems with the ones I've bought there, but I always check that the roots aren't coming out the bottom of the pot and that the plant looks healthy. Re: Build Thread - Modern Formal Garden on a Budget 24Nov 09, 2012 1:36 pm very nice how thick are you going on the concrete below the paving? thinking of doing something similar Re: Build Thread - Modern Formal Garden on a Budget 25Nov 09, 2012 3:16 pm Thanks for the kind words everyone. kek Re plants: Aumanns on Plenty Rd have good quality plants, but stock varies... maximus Hmmm - very interested - what kind of budget? What did you do yourself and what did you get tradesmen to do? XT4V very nice how thick are you going on the concrete below the paving? thinking of doing something similar Re: Build Thread - Modern Formal Garden on a Budget 26Nov 09, 2012 3:24 pm syahrr01 We had 100mm of reinforced concrete under every paver, including stepping stones. Underneath the concrete is around 75mm of compacted roadbase. Some say we're over doing it. I wouldnt say overdoing it, more of a guarantee it will last Re: Build Thread - Modern Formal Garden on a Budget 27Nov 09, 2012 6:12 pm syahrr01 maximus Hmmm - very interested - what kind of budget? What did you do yourself and what did you get tradesmen to do? Unfortunately we had to rely on tradies for almost all the hard landscaping elements. I only did very minor things such as waterproofing membrane, varnishing timber surfaces and sealing the granite pavers. From this point onwards, we're looking to do everything ourselves. Our overall landscaping budget is around 10% of the total value of the property. Thanks! Gives me some idea of what might be possible. I'm thinking of factoring some landscaping construction into the build as it's probably cheaper/easier that way (although that will depend on the builder I select). Maybe a rendered concrete-block wall for a future vertical garden and low water wall. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Build Thread - Modern Formal Garden on a Budget 28Nov 09, 2012 8:08 pm Pretty fancy for a budget! Looks fantastic. GOODLIFE - Bravo - BUTLER http://getmistyfied.blogspot.com.au Display 20/02/2012 PPA 01/04/12 Prestart: 25/07/12 Settlement: 31/07/2012 Contracts:August Slab 19/11/12 BRICKS 10/11/12 Roof 16/01/13 Re: Build Thread - Modern Formal Garden on a Budget 30Nov 27, 2012 1:53 pm Hi Looks very good Can I ask what size the pavers are and how much they cost each as Im looking for some like that to use as stepping stones Thanks Site Cut 8/04/12 Slab 13/04/12 Frame 18/04/12 Roof 07/05/12 Lock Up 06/06/12 Keys 30/08/12 Re: Build Thread - Modern Formal Garden on a Budget 31Nov 27, 2012 9:30 pm coobri Can I ask what size the pavers are and how much they cost each as Im looking for some like that to use as stepping stones Our granite pavers are of varying sizes. Stepping stones, for example, are 1000x250mm. These were cut to specified dimensions to minimise waste and installation efforts. Cost-wise the standard 20mm ones are roughly $52 per sq m. The 30mm bullnose are much dearer. Re: Build Thread - Modern Formal Garden on a Budget 32Nov 26, 2018 7:52 am A bit of thread necro, but I thought it would be fun to show before and after. 6 years after that is. I would call this the completion of our last stage of landscaping - planting. Images are on the same order as the first post. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 1.Front retaining wall Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 2. Side garden with Gravel Path Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 3. Stepping Stones on South Side Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 3. Pergola Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Coming back to your old stomping grounds, huh? Renovations on a budget can be quite the journey. It's like giving your house a new lease on life. The twist of not knowing… 1 3539 Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 11387 |
