Disco Stu
I don't think caveats is the right word... easement maybe?
Any way, it was a condition governing what you can and can't do on the lot.
covenant!
Browse Forums Building A New House Re: 25Oct 30, 2012 9:44 pm Deposit Paid 31/10/12 Selections 25/1/13 NHC 28/2 DCA 20/3 Siteworks 2/5 Slabbed 20/5 Wall Frames 3/6 Brickwork Finished 2/7 Lock Up 19/7 viewtopic.php?f=31&t=58864 Re: roof pitch costs extra??? 26Nov 06, 2012 6:14 pm higher pitch means higher roof volume. That requires a bit more timber for rafters and struts. But its is a very marginal cost difference. If you went above 25 degrees then you have to include worksafe requirements, so you can expect a much larger jump in costs Re: Roof pitch clause 27Nov 06, 2012 6:17 pm Disco Stu I too have signed up with The Homebuyers Centre and ran into the 25° roof pitch issue. The original house design ( Aussie Alfresco ) was altered for rear access. Land caveats on the Butler lot then required a 25° pitch, costing $1600. The original 21° pitch was saved simply by running eaves across the entire front of the house. In fact, I used most of the $1600 credit to finish off eaves to the entire house. I really wanted a lower profile roof, especially on a coastal, wind prone lot. What an odd little clause! Not really an odd clause, in fact it is quite common. Covenants like this are to prevent a sea of awful looking low pitch cheap housing. Sadly it doesnt work. 90% of housing in Perth is still cheap and nasty looking. Now if you want a bold set of guidelines look at Perry Lakes. No pitched roof are allowed. No horrible 2c facebrick allowed. Why don't you call and talk with someone at the town planning in your council? 1 2209 Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4270 |
