Browse Forums Lighting + Lighting Design Re: LED Down lights and Dimmers 4Oct 26, 2012 9:09 pm https://forum.homeone.com.au/viewtopic.php?f=38&t=44762 My Owner builder journey extending a 1930's Bungalow Re: LED Downlights and Dimmers 5Nov 02, 2012 7:51 am Maybe you could of negotiated some more electrical work for the return of those dimmers, the clipsal dimmers are usually a stock item for most electricians I know. **second post of the day for ledsh0pper..... how hard is it to front up some money and buy an advertising membership. Re: LED Downlights and Dimmers 6Nov 04, 2012 7:53 pm I am currently building a house and and am doing my own electrical (im a sparky) and looking at purchasing the D1000's along with clipsal saturn series dimmers - the 60 Series Saturn Mechanism 4061E2PUDM which has an integrated switch. What I am asking is if these dimmers wont work properly with the clipsal dimmer and I install the luxman T400P dimmer: - 1. will the luxman T400P dimmer fix into the clipsal saturn series wall plate along with the saturn series slimline knob?... and - 2. does the luxman T400P dimmer have an integrated switch, or will i need to add another saturn series switch mech to my list of to get items and get for example a four gang wall plate instead of a three gang wall plate for this extra switch if the luxman does not have this? I am at the point where I will be looking at purchasing these fit-off items very shortly and it would be great to know what equipment will work with these lights, cheers. Re: LED Downlights and Dimmers 7Nov 05, 2012 10:42 am Georgeo, you should be able to use the new clipsal push button (31E2PUDM) with much lower dimming available. Re: LED Downlights and Dimmers 8Nov 09, 2012 7:20 pm Thanks think_wise, but I think the 31E2PUDM is for the clipsal 30 series and i believe I'll need the 4061E2PUDM for the saturn series is that right? http://updates.clipsal.com/ClipsalOnline/Files/Brochures/W0001425.pdf I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10830 Yes, unless you are in a low intensity rainfall area or the area is protected from rain. Do you have access to NCC Part 2 or can you download it? I can email you a copy… 10 12843 |
