Browse Forums Heating, Cooling & Insulation Yikes - just got our electricity bill! 7Aug 31, 2012 9:29 am For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Reverse Cycle air con -- your electricity bill 9Aug 31, 2012 10:25 am For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Reverse Cycle air con -- your electricity bill 11Aug 31, 2012 1:57 pm Explains why so many people go to bed early and read For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Reverse Cycle air con -- your electricity bill 12Sep 01, 2012 8:17 am B STAR how big is the heating area? and what temp do you set We heat ~85m2, the living area to 21C, the bedroom is usually 19.5C. The house is bigger but unused room doors are kept closed. For about half the winter our air-con was using the return air temp sensor and the living area was hitting 25C if we didn't turn the unit off manually. Now that I've switched the unit to use the controller's temp sensor the temp is a stable 21C and it's using less electricity. As someone else mentioned Adelaide has had a colder than normal winter Re: Reverse Cycle air con -- your electricity bill 14Sep 01, 2012 9:10 am Ours was around $270. We set to 20-21 in the day time and 19 at night time. During that bill period we had it on almost 24/7 as the kids were sick. I try turn it off in day now its getting bit warmer How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5928 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 |
