Browse Forums Heating, Cooling & Insulation Re: Actron Air-Thoughts/Reviews from People who already have 28Aug 13, 2012 12:07 pm Building with Jandson Homes - Eclipse 18. http://adgnetworks.blogspot.com/ Re: Actron Air-Thoughts/Reviews from People who already have 36Aug 28, 2012 7:08 pm MY builder was installing an actron classic but when I asked for a esp+ I was told the smallest unit being 13kw was too large for my home (living areas 115 sq mts). My previous home I have a daiken inverter ducted system 7kw. So it looks like I can only install 10kw daiken. Re: Actron Air-Thoughts/Reviews from People who already have 37Aug 28, 2012 7:23 pm Can't give you specifics on a 16kw system, but we just had our 23kw ESP plus system installed last week in our build. So far we are really impressed with it. We aren't living in the house yet, but we are there most of the day, every day working inside, so have been testing it out. We went for the ESP Plus model as it has the ability to run on variable speed fan mode, not just the standard 3 speeds. Having already had a ducted evaporative air con unit in our last house, with a variable speed fan, we wanted similar. Nothing worse than trying to sleep with a contsant strong breeze blowing down on you...instead of a nice gentle hardly noticeable one. When it Actron first starts up, in a cold house, you initially hear some 'air thru the vent' noise, (as the fan is obviously working a bit harder) but that soon disappears as the fan automatically backs itself down (running on ESP mode), quietly adjusting itself to maintain the temp set from there on. The outside unit itself we can't really hear it inside, having placed it on the side of our garage. Only notice it when we are outside, but it's no worse than the evaporative air con was....if anything it's quieter. We also added the option of another controller to our Main bedroom, so at night we can run just our bedroom only (and the kids bedrooms too...if they are home), not having to run the living area also (where the main controller is with the thermostat). The bedroom controller also has it's own thermostat, so it can sense our bedroom temp and properly adjust through the night....not wasting money running an empty living area. (without the 2nd controller.....if we ran the just the bedroom......the system would be trying to run using a thermometer in cooling down...not on.. lounge.. for guidance) Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Actron Air-Thoughts/Reviews from People who already have 38Aug 29, 2012 11:21 pm Thanks jj1, I'll be asking for an updated quote for SRD160c. I found that it's a bit difficult to find a list of model from actron's web site. I couldn't even find the classic SRA160. Hi delatite13, your explanation on the thermostat is exactly what I'm looking for. Seems like the thermostat only comes with the controller .. does it mean that if I want to have 4 zones, I'd need 4 controllers? It's just that having a zone without a local thermostat seems like a waste of electricity. I'm aware that with esp plus i can only have 1 temp at a time. Btw, Do you still remember how much did you spend on an additional controller? Thanks. Re: Actron Air-Thoughts/Reviews from People who already have 39Aug 30, 2012 8:34 am The extra controller wasn't expensive, less than $100, just can't remember exactly how much. Unfortunately you cannot have more than 2 controllers with the ESP plus. We looked at that option as well as it could make life easy, but the system doesn't have that option. The only option if you want individual control in each zone is to get the Ultima system, but at a pretty hefty price for only + or - 2 degrees. Each controller (the 2 we have) can operate, turn on/off each zone. There is a master unit and a slave unit which will work when the master is turned off. Each one has the ability to operate all your zones, we have 8 zones for maximum flexibility. The more the better. You need extra software for the extra zones from the standard 4, about $800 I think, but certainly gives the option to zone the house, to get maximum benefit. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Actron Air-Thoughts/Reviews from People who already have 40Aug 30, 2012 12:19 pm peace97 if you go from their homepage>brochure>ducted systems there seems to be a lot of info near the end of the brochure If your patio is going to be 35 sqm then that's going to need Council Approval. The fact that they previously approved your 25sqm patio will be irelevant 1 6571 We are looking to do a KDR with fairhaven homes, Have seen plenty of good reviews about them pre construction and plenty of negative reviews about them during contruction… 0 18496 I would think twice. I have signed up with Sienna to build a town house. My first question to them was, will there be a hold up on the build if all the town houses are… 1 3436 |
