Browse Forums Building A New House Re: :(Slab set back too far back, no backyard, slight land s 12Aug 27, 2012 8:14 am Hi bigz! When we first got our plans drawn up they had split the house so there would be steps in the middle of the house as the front would be lower than the back of the house. We weren't happy with this and told them, they ended up cut and fill method of the soil to give us the house on one even level (apart from the garage that is lower than the rest of the house. The only reason they drew up the plans with the split was so we would avoid costs as we had a land slope. So there are ways around it if you are willing to pay Goodluck! www.tinas-cakery.com Building a Monte Carlo with Fowler Homes. Our Build Thread --> https://forum.homeone.com.au/viewtopic.php?f=31&t=49218 Re: :(Slab set back too far back, no backyard, slight land s 13Aug 27, 2012 9:15 am Are you able to post a pic of your site plan with contours? Certainly possible to position your house where you want but with a slope will require cut/fill and retaining walls and/or using a split level house design, all depends on the amount of slope really. Build Thread: viewtopic.php?f=31&t=57639 Re: :(Slab set back too far back, no backyard, slight land s 14Aug 27, 2012 11:33 am Is it poss to move the house over so the side with the alfresco has a bigger yard,have to read back as your block maybe to skinny for this. If its not this may save earthworks costs & solve the prob. It means you may have a wrap around yard out the back but still one that is big If i remember right (my folks built up there) the soil is mostly sandy,but extra sand to fill can be quite exy. And i would get another opinion. Post a pict & those in the know will/maybe able to help. Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: :(Slab set back too far back, no backyard, slight land s 15Aug 27, 2012 11:35 am Ok forget what i said about moving the house over no room. Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: :(Slab set back too far back, no backyard, slight land s 16Aug 28, 2012 12:46 pm I spoke to the builder yesterday arvo. Our back yard is 2 meters and if we were to move the house forward and pay the extra (10-20k depending on how we chose to do it) for cut and fill, retaining walls, lowering the garage and adding steps etc, we will then have a 3.3 meter backyard. Not worth it.. I didn't even know till now that, that's all we'd be gaining. We have a very big house and not going to spend the extra money when we will only be gaining an extra 1.3 meters. I'm glad I looked into it because now I know all my options.. We do have hour house as far to the left as we possibliy can so we do have more room around the alfresco area which is great. Better than nothing. We will eventually look into getting a fence for the front yard as our second backyard area. I hope this will add to the re sale value.. Builder Plunkket Homes. Preliminary Agreement 19/05/2012. Pre Start 13/08/2012. Building License 15/02/2013. Re: :(Slab set back too far back, no backyard, slight land s 17Jul 06, 2013 9:06 pm Looks like that is the only reasonable choice you have BIGZ. Use your front yard later on Re: :(Slab set back too far back, no backyard, slight land s 18Jul 07, 2013 1:47 am bradster181 Looks like that is the only reasonable choice you have BIGZ. Use your front yard later on Naw thank you I agree! I posted this awhile back and this is definitely what Im doing now and it works perfectly Re: :(Slab set back too far back, no backyard, slight land s 19Jul 07, 2013 10:28 am In that case where are the pictures of the progress to feed the picture piggies on homeone.... Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 25027 The OP has gone The latch and striker are definitely not aligned but there was no point trying to help the OP understand that. Hence the reason they are no longer with us. 12 5763 Hi All, We have recently purchased a sloping block (3.5m fall building envelope, 6m overall). Just wondering if you know of any good builders that you would recommend for… 0 2280 |
