Browse Forums General Discussion Re: Fixing Eye Bolts to Ceiling Joists 4Aug 05, 2012 8:47 pm Ranson52 Hi All - I need to fix two eye bolts to a ceiling approx 1 meter apart. This could be increased to 1.5 meters if the joists are spaced appropriately. These need to support a weight of approx 180 kgs. I have no experience of such things, so my question is, would a typical West Australian home built around year 2000 have ceiling joist capable of supporting such weight ? Any advice would be welcome. Your house would have trusses for the roof, even though they would probably support that sort of weight, I would not recommend hanging 180 Kgs off a truss roof. What are you planning on hanging off the ceiling? Re: Fixing Eye Bolts to Ceiling Joists 5Aug 05, 2012 8:52 pm PaulMac Ranson52 Hi All - I need to fix two eye bolts to a ceiling approx 1 meter apart. This could be increased to 1.5 meters if the joists are spaced appropriately. These need to support a weight of approx 180 kgs. I have no experience of such things, so my question is, would a typical West Australian home built around year 2000 have ceiling joist capable of supporting such weight ? Any advice would be welcome. Your house would have trusses for the roof, even though they would probably support that sort of weight, I would not recommend hanging 180 Kgs off a truss roof. What are you planning on hanging off the ceiling? The item is a peice of personal equipment, that will hang from two points. I am told the equipment is capable of supporting 230 kgs once suspended. It comes in the form of a cradle, so the weight is spread between the two anchor points. If not able to use the recommended method of screwing the eye bolts into joists, do I have any other options I could consider ? Re: Fixing Eye Bolts to Ceiling Joists 6Aug 05, 2012 9:38 pm It may be possible to add a couple of heavy duty beams in the ceiling space that run parallel to the trusses and sit on the walls either side of the room, depending on whether you can a) actually get them into the roof space and b) whether there are any obstacles in the way, such as noggins, etc. This way the load will be supported by your wall, not the roof frame. Re: Fixing Eye Bolts to Ceiling Joists 7Aug 06, 2012 10:32 am Sbryzak is on the money as its too much weight to concentrate on one ceiling joist Arfur Re: Fixing Eye Bolts to Ceiling Joists 8Aug 08, 2012 8:23 am Thanks for the responses. I have decided to abandon my original plan and am having a metal frame (similar to a garden swing) made to do the job. Your responses have been very helpful and I appreciate your thoughts. Re: Fixing Eye Bolts to Ceiling Joists 9Aug 08, 2012 11:30 am Ranson52 Thanks for the responses. I have decided to abandon my original plan and am having a metal frame (similar to a garden swing) made to do the job. Which is going to look a whole lot uglier. If you have a conventional style roof you may be able to hang it off an underpurlin Arfur Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 5816 Thanks for all replies. I just noticed now the pictures I added to post right on top of page were wrong. I attached pictures showing "current" and my "suggested" floor… 9 14609 Houses have been framed on floor joists since settlement, chipboard flooring is only around for 50 years or so, so why would it not be satisfactory? However exercise skill… 3 16798 |
