Browse Forums Kitchen Corner Re: kitchen size 2Jul 26, 2012 1:02 pm Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: kitchen size 3Jul 26, 2012 1:15 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: kitchen size 11Jul 26, 2012 9:42 pm Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: kitchen size 12Jul 26, 2012 9:44 pm Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: kitchen size 15Jul 30, 2012 7:03 pm travelbug What I do when I want to rearrange a bathroom is- (I know you are doing a kitchen but same principal applies) draw the room on the concrete (I use the garage floor). Draw in the furniture (cupboards or bath etc) then two of you stand in it. Do you feel squashed? It gives a better feel for tight fitting things and space between corners etc. (we even pretend we're having a shower LOL) We need to get a life I know. Basic but it works for us. Sorry to hijack but I just wanted to say thank you to travel bug for the advice on drawing it up on concrete. I just did this with one of our bathrooms and decided to change it, just in time for the plumber to start his drainage work tomorrow. Re: kitchen size 16Jul 31, 2012 6:04 pm xxkatxx Ok I've had a try at drawing up a picture... I'm thinking maybe delete the WIP and have the kitchen wrap around and just have big cupboards for the pantry? I would not want to have a pantry at an outside wall, which in principle takes away any daylight in the kitchen. I would have tall cabinets on the opposite side (bed 1). Depending of the space between the two rows of cabinets, either a galley or u-shape kitchen but then with "dead corners". The door to the laundry I would move the depth of the tall cabinets to the right. A wall on both ends of the cabinets could enclose them. Re: kitchen size 17Aug 01, 2012 2:59 pm where is the current door position for the bedroom and the laundry? 2010, June : Land bought (1700sqm, battleaxe block). That's it so far! We're in the design phase .... Re: kitchen size 18Aug 01, 2012 5:15 pm The doors are opposite each other with the laundry one behind the fridge. the bedroom one is set in a mmetre or so. I've just realised that the plans we had drawn up used the wrong block size so ee get an extra 70cm of kitchen width! Im going to do some drawings with a long WIP where the fridge is down into the laundry area and then wrap bench around the wall end and create and entry to the laundry in the kitchen. i didn't want to have to go thru the kitchen to get to the laundry but it solves a lot of problems! Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 1885 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7701 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3730 |
