Browse Forums Kitchen Corner Re: flushmounting an induction cooktop- need pro advice 2Jul 18, 2012 1:57 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: flushmounting an induction cooktop- need pro advice 4Jul 18, 2012 3:04 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: flushmounting an induction cooktop- need pro advice 6Jul 18, 2012 7:50 pm Thanks for the reply guys. I think they can do it, its just that they have had problems in the past with the stone cracking because the pots slide off the cooktop and bang into the stone...I told him it is meant to be flush, so there should be no contact with the stone if the pan slides off the cooktop while cooking....don't think he understood what I meant. he is asking the stone mason again to see if they will agree to do it. I am in canberra unfortunately Re: flushmounting an induction cooktop- need pro advice 7Jul 23, 2012 4:01 pm Flush mount should not be an issue, a stone mason will re enforce the corners of the cut out. These are becoming more and more popular. With 25 years kitchen experience and a passion for what I do, I have joined this forum to offer advice or at least my opinion on all things relevant to kitchens. I was a cabinetmaker by trade and am now a senior manager of a kitchen company. Re: flushmounting an induction cooktop- need pro advice 9Jul 27, 2012 11:37 pm nope no idea who it is...can you recommend me one? i've seen some pictures where the induction top sits on top..its about 7mm doesnt look too bad at all... flush is more streamline i guess....its just that so many people recommend(the miele rep, told me to get the 6282, which is framed) against it... and 2 kitchen companies. Re: flushmounting an induction cooktop- need pro advice 10Sep 12, 2012 8:30 pm Just found this thread and wondering what you ended up with ? We're sort-of considering flush-mount, but are worried that as the "hole" in the top won't be **EXACTLY** the same size as the glass, the "gap" will fill up with "gunk", or if the installer uses silicon to fill in the gap then the silicon will look yucky reasonably soon ............. P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: flushmounting an induction cooktop- need pro advice 11Sep 12, 2012 9:28 pm Pepsi_Drinker Just found this thread and wondering what you ended up with ? We're sort-of considering flush-mount, but are worried that as the "hole" in the top won't be **EXACTLY** the same size as the glass, the "gap" will fill up with "gunk", or if the installer uses silicon to fill in the gap then the silicon will look yucky reasonably soon ............. P_D If done correctly there would be around 1mm gap all around A bank is a place that will lend you money only if you can prove that you don't need it... Re: flushmounting an induction cooktop- need pro advice 12Sep 12, 2012 11:29 pm Buttercup Pepsi_Drinker Just found this thread and wondering what you ended up with ? We're sort-of considering flush-mount, but are worried that as the "hole" in the top won't be **EXACTLY** the same size as the glass, the "gap" will fill up with "gunk", or if the installer uses silicon to fill in the gap then the silicon will look yucky reasonably soon ............. P_D If done correctly there would be around 1mm gap all around Thanks for that, 1mm sounds pretty reasonable !! Is this an "easy"* job for a stone-mason to do, and by that, is it the sort of thing where he can just program the cooktops dimensions into a CNC cutter / grinder / saw / router / other $$Zillion tool / and he get perfect results every time, or is a highly skilled task that involves extremely intricate cutting / polishing by hand to get the hole hand cut and polished with millimetre precision ? Thanks, P_D *Not for one second trying to imply that the job of stonemason is anything other than a highly skilled craft, we all use machinery to make our tasks easier !! . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: flushmounting an induction cooktop- need pro advice 13Sep 13, 2012 1:19 pm No its not an easy job and thats why it cost a bit to have done. Yes you will end up with a small 1mm gap between the cook top and stone. You either put silicon in it or leave it to collect grime. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: flushmounting an induction cooktop- need pro advice 14Sep 13, 2012 9:28 pm the induction top is going to sit above the bench It will be 7mm high i went around to display homes and looked at similar setups and was fine with it in the end. I did not like the look of silicon around the top, and if left open as many have said here, grime etc would collect in it. Re: flushmounting an induction cooktop- need pro advice 15Sep 13, 2012 9:35 pm I have a black glass gas cooktop (Bosch) hich sits above. Looks pretty schmick actually. Though would probably look better flush. I gather the induction would be along the same lines. Re: flushmounting an induction cooktop- need pro advice 16Sep 14, 2012 1:15 am unfunkable .......I did not like the look of silicon around the top, and if left open as many have said here, grime etc would collect in it. Our concern 110% There's the concern too that you don't get to pick your stone-mason with a regular builder, and someones professional 1mm gap might turn out to be 4mm - 5mm or so, that you WOULD notice !! So it's just luck of the draw who your builder uses ..... Probably not worth the risk, IMHO !! P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6824 4 15657 My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance 5 13037 |
