Browse Forums Building A New House Re: Can a house build on the boundary line? 3Jul 16, 2012 11:00 am 29/05/12 - Contacts Signed 18/06/12 - Land Settlement 03/07/12 - Building Approval 20/07/12 - Slab Down Re: Can a house build on the boundary line? 4Jul 16, 2012 11:17 am Yes you can - we did the same thing - most councils will allow maximum 10 metres on boundary at 3.6 metres high. Hope this helps Sleven Moved into our Atlantique MkII 36 by Carlisle Homes Re: Can a house build on the boundary line? 6Jul 16, 2012 11:46 am I'd say hello and then let them know to hang your gate you are going to require to attach a post the their wall (ie the fence) Re: Can a house build on the boundary line? 7Jul 16, 2012 11:59 am humble You can. However the friendly neighbor thing to do would be to ask. Check to make sure that is on the boundary (not just inside). If it is the boundary you can attach a gate as it has become common property. If the wall is just inside their boundary, you can do as the above and ask if they mind - otherwise you may need to erect a post. Re: Can a house build on the boundary line? 8Jul 16, 2012 12:09 pm atom_ute humble You can. However the friendly neighbor thing to do would be to ask. Check to make sure that is on the boundary (not just inside). If it is the boundary you can attach a gate as it has become common property. If the wall is just inside their boundary, you can do as the above and ask if they mind - otherwise you may need to erect a post. I am 150mm in, as is my neighbor. I had a chat with mine and he was happy with bolting to the wall. But I asked. thats the key. In WA zero lot is actually zero lot. We build 10mm in from the boundary. My house and my neighbours house have garages that sit only 20mm apart. When I had our roof done… 3 7119 I am building in claymore NSW and this is shown in the building envelope plan. … 0 10137 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 46169 |
