Browse Forums Home Theatre & Automation Re: CAT6 Wiring cost "per point" 3Mar 03, 2012 5:20 pm Electrical - Automation - Smart wiring - New homes - Commercial - Data cabling] 1300 050 315 www.cenemelectrical.com.au www.facebook.com/cenemelectrical Re: CAT6 Wiring cost "per point" 5Apr 11, 2012 8:38 pm Building a Delta 21 at Craigieburn - http://homeofzero.blogspot.com.au/ Deposit: 26/02. Contract: 22/05. Settlement: 29/05. Site start: 18/10. Re: CAT6 Wiring cost "per point" 7Jun 28, 2012 9:34 pm my house blog: http://sugarloafdrivebuild.blogspot.com/ Re: CAT6 Wiring cost "per point" 9Jun 29, 2012 1:08 pm Afterwards (after build is complete) is much tougher (and expensive?) as it's essentially a retrofit then because you have all the plaster up. Especially a double story. Correct me if I'm wrong as I am no expert. My Hamptons build (completed): viewtopic.php?f=31&t=63370 Moved in Wednesday 11th Dec 2013 Front landscaping completed June 2016 Re: CAT6 Wiring cost "per point" 10Dec 26, 2016 7:26 pm do it yourself mate and then do the termination through sparky, its very easy tie or tape a CAT 6 roll cable to a conduit and keep passing thru the ceiling, either at frame stage or else when all is build up, u ll have to run the cables thru yellow tongue and there is always a inch space between the noggins in studs. Its easier at frame stage just ask the building supervisor that you will bring in your sparky and go on saturday do it with help of a friend, but please very careful from OHS point of view and use a plank to balance your weight on the ceiling frame... since you have 2 floors, it doesnt matter how many floors the techinique is simple so you can use with all the single storey or double storey houses.... you can use the cable loose in the ceilings during frame stage as they are not affected and once plasters goes up you can come back to punch holes in wall and drag the cable out get sparky to terminate for u into a cat 6 data jacks and then couple it to the face plates your self and screw it to wall, it is illegal to do termination yourself and would recommend a qualified sparky. Re: CAT6 Wiring cost "per point" 11Dec 27, 2016 6:58 am It is a common misconception that only the terminations must be carried out by a registered cabler. It is illegal to do any communications cabling yourself, not just the termination. In fact, the regulations aren't really concerned about termination at all. The primary purpose of the cabling rules (S009) is safety, for both end users and telecommunications network workers. The biggest risk comes from cabling being insufficiently separated from power cabling and becoming inadvertently energised, but there are also risks posed by Earth potential rise and by other hazardous services, such as gas lines. Incorrect or poor termination may result in the cabling not being functional, but this is a secondary concern of the regulations. To install data cabling you require a restricted or open cabling registration plus a structured cabling endorsement. An unregistered person may do the work if they are actively supervised by a registered cabler with the appropriate registrations. This means that they are present at all times while the work is being done. Re: CAT6 Wiring cost "per point" 12Oct 12, 2017 9:06 am Builder prices for data points seem to be $130 - $150, give or take. I recently moved out of my Porter Davis built home, where we paid them thousands for data cabling and had a sparky come out and cable my new place up. Cost per point was closer to $70, and I had the pleasure of being able to choose my own rack rather than being limited to PDs awful list of only one choice (that was not suitable). This guy worked on an hourly rate plus materials, rather than a per point cost, and I had him do a ton of other work. So for less than half of what PD charged me for a similar number of points, I managed to get the data points, a dozen power points, the rack installation (I bought it myself but he installed it and terminated all my points into a patch panel), and the satisfaction of knowing it had been done properly. And as paulw11 says, you can't do the cabling yourself. Yes, you can run pre-made cables over the floor but you can't install fixed cabling or cables that run through cavities, nor can you terminate the connections. If you get to the stage where you're running Power over Ethernet down any of these and something goes wrong (ie. fire) and the insurance company asks to see your compliance certificate you might have a crummy day. Just get it done properly. Re: CAT6 Wiring cost "per point" 13Dec 15, 2017 12:39 pm My builder is charging $80 per point, which I was pleasantly surprised with...until they told me they charge $160 for a double and $320 for a quad!!! I have tried to explain that it doesn't cost double to provide a double etc but to no avail. They also won't terminate to a patch panel, only to wall plates, but said they will leave the bare wires hanging out the wall if I want to do it myself afterwards. Strange..... As expected they won't allow me (or my electrician) any access to do it Re: CAT6 Wiring cost "per point" 14Dec 19, 2017 1:15 pm brokenstick My builder is charging $80 per point, which I was pleasantly surprised with...until they told me they charge $160 for a double and $320 for a quad!!! I have tried to explain that it doesn't cost double to provide a double etc but to no avail. They also won't terminate to a patch panel, only to wall plates, but said they will leave the bare wires hanging out the wall if I want to do it myself afterwards. Strange..... As expected they won't allow me (or my electrician) any access to do it It's normal for builders to charge "per cable run" as opposed to "per outlet". I just had to suck it up, given it's going to cost much more doing after the plasterboard has gone up Re: CAT6 Wiring cost "per point" 15Apr 23, 2018 4:36 am It really depends, everybody charges a different price for CAT6 cabling. For example here in some of the Data cabling in Perth we did, we would charge perhaps $130-$180 per point, but that is private jobs and not ones where multiple points are being installed. Some builders or smart wiring companies would probably charge even upto $300-$450 per point effectively once you work it out. So it really depends on who is doing the work, how many middle-men and mark up there is. Just remember, there are advantages and disadvantages of going or not going through your builder and/or their provider for structured cabling. Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV Re: CAT6 Wiring cost "per point" 16May 20, 2018 7:16 pm AllCastle Homes charges $138 for Cat5E and $168 for CAT 6.... Big catch is still need to pay $110~ $140 to terminate them... ( Fuming at the moment but think will end up going ahead with minimal number I need and do the rest post build.. what is frustrating id s colleague of mine who is building with First Style Homes charges only $99 for Cat 6 and other items such as power pt , switches etc all seems to be 15% less which is all arranged through Clipsal tec in Marsden Park. 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 4112 Building Standards; Getting It Right! Hi All, We have a fall from road to garage front. But we cannot put a drain/grate because no discharge point put by the builder. Now they complain not enough space for… 0 9297 Hi, I have this sewer inspection point sitting in an odd spot in the rear of my yard: https://imgur.com/ghLI98q What I'd like to do is put a firepit in that corner of… 0 6615 |
