Browse Forums Building A New House Re: Project homes with rear balconies 4Jun 23, 2012 5:31 pm I've noticed that at the front of houses, balconies often aren't drawn in the floorplans; I suspect they're often only included if they are part of the "facade". Maybe you need to find house designs with the master bedroom to the upstairs rear, and ask the home-builder about a balcony off the master? I notice, for example, that in gogo65's suggested Metr!con Laguna the balcony only appears in the online plans if you choose one of the options for an "outdoor room" downstairs. Re: Project homes with rear balconies 5Jun 23, 2012 5:58 pm gogo65 Metr!con laguna Unfortunately, I dislike the facade options, intensely......... Thanks for the recommendation though. The Wisdom homes one did not really open up at the back due to the rumpus so not keen on that either. Will look at Clarendon next. Project homes with rear balconies 7Jun 23, 2012 7:00 pm FW, I believe a lot of plans can include a rear balcony on top of the alfresco. I saw a PD under construction recently, and I'm pretty sure any M'con with a rear master will have that option. Previous comment is correct, the standard plans often will not show this. Re: Project homes with rear balconies 8Jun 23, 2012 9:01 pm That's useful to know if that is the case as we can then take pretty much any project home with the master at the back and stick on an al-fresco and balcony upstairs. Have gone the reno route so far, but the quotes on the plans are coming in at $550-$650k which is v hard to justify on a very average 1930's 3 bedder, thus looking at the new house alternative Project homes with rear balconies 9Jun 23, 2012 11:00 pm Make sure the original plan's alfresco lines up with the master IYKWIM. There's an M'con plan where the balcony can be accessed from the master AND an upstairs sitting area. I'll chase it up for you if you want. Re: Project homes with rear balconies 12Jun 26, 2012 9:49 am Check out Eden Brae "Windsor", but get ready on their prices upgrades. Also, check your back neighbours, they might reject that idea having your balconies at the 2nd floor...This might happen at council stage approval, I read some people here have problem and must install screening because the neighbour reject it due to their privacy.... Re: Project homes with rear balconies 13Jun 26, 2012 10:20 am It can be a council regulation rather than just neighbours, in our council if the balcony is more than a metre high off ground level you must have privacy screening Also there is a new Eden brae that has a rear balcony on display at home world maybe the waldorf same design as the porter Davis in Melbourne Re: Project homes with rear balconies 14Jul 17, 2012 8:23 am willcres Check out Eden Brae "Windsor", but get ready on their prices upgrades. Also, check your back neighbours, they might reject that idea having your balconies at the 2nd floor...This might happen at council stage approval, I read some people here have problem and must install screening because the neighbour reject it due to their privacy.... We would do a CDC to avoid any neighbour problems. Thanks for all the replies. Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8432 DIY, Home Maintenance & Repair That laser level looks lovely! We bought one for less than a quarter of that price off eBay. It worked really well for us and it's still going now, five years later. After… 1 16704 |
