Browse Forums Windows & Doors Re: Is my door frame adequate 15Jun 18, 2012 2:36 am Hi Amgsl55. The frame you have installed is indeed adequate for the door installed. It's a simple fix. If the hinges are binding or the weight of the door is causing the frame to unclip, the clip in door stop can be removed, and the glass pockets in the 2 frame sections screwed together (concealed under the clip in door stop) and the problem won't happen again. The reason it only happens when the door is open wide is the weight is pushing the 2 clipped sections apart, and when closed it naturally transfers the weight to push the sections back together. This is 100% true. You can not hang anything on steel frames. very frustrating 8 10655 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 4176 The frame work needs to be fully and adequately supported as they are most of the time the load bearer. A steel angle bolted to slab edge and bottom plate could do the… 1 940 |
