Rups, Is this the standard smart wiring box or have you added extra points as you have some black wires that are not connected, what is the purpose of the red string...
Standard wiring. Phone connected to krone block in top left corner. Data points bottom left. TV points (connected to powered distribution block) on the right. The black wires not connected (marked as Fox 1 and Fox 2) are the ones I referred to as not having been terminated anywhere. The red string tied to the pipe is a draw wire to the side of the house where Telstra will terminate the fibre and will need to run a cable back.
