Ah thanks for that !!
If there's only a few that have cold-only connections, and there's solar hot-water in your life, or you can see that there will be in the future, then as long as you stay away from these cold-only models you'd be OK !
P_D
Browse Forums Laundry Appliances Re: Top load or front load washing machine 41Jun 27, 2011 8:59 am . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Top load or front load washing machine 42Jun 27, 2011 9:24 am . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Top load or front load washing machine 45Jun 27, 2011 6:32 pm Cassie 28/7/11 - Slabbed 15/8/11 - Framed 19/9/11 - LOCKED UP! 6/10/11 - Kitchen in! 11/11/11 - It's all OURS! Pg 12 Follow our build: The Noodle Family - Preston in the Hills Re: Top load or front load washing machine 48Jun 29, 2011 9:26 am Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Top load or front load washing machine 50May 26, 2012 8:53 am These days washing machines are quite tricky. You never really know what are you getting in terms of excat behaviour and washing programs. We just replaced our old (and wonderful) Whirlpool front loader with another brand and - it's not what I expected from the user manual! Geeeeeeez .... They seem to write manuals for more than 1 model (even though the title of the manual mentions only one specific model number). Should have stayed with Whirlpool ... My signature is distracting people from my wise posts ... Re: Top load or front load washing machine 51May 31, 2012 8:44 pm Six months in using our new Miele and the pain of the initial price slug is long forgotten. Just to add or comment on a few of the points raised here. Our machine doesnt have a stop and add function, however it will open a couple of minutes into the cycle. I interrupted the cycle once to see what would happen and found that because the machine used so little water in a cycle, it doesnt matter a toss if you have to start again, except for the time factor. We have an instantaneous HSW and the machine copes quite well with it.
I dont think I would ever go back to a top loader, hopefully given the Miele reputation we wont have to consider that decision for a very long time to come. Re: Top load or front load washing machine 52Jun 01, 2012 7:59 am My biggest grudge so far with my new machine is the spinning. It's a 6.5 kg machine with max 1200 spin speed. I find the 1200 spin barely dries the clothes up to the level of some 800-900 in the old machine! It only once gave me a drier result than my old washer (which was 1000 max), and I think it was the case of a perfect load weight. The old machine was drying perfectly every time and regardless of the amount of washing in it! Seems like I'll have to start weighing the washing before I load the machine My signature is distracting people from my wise posts ... Re: Top load or front load washing machine 53Jun 01, 2012 10:46 am We got a front loader. It takes soooo much longer than our old top loader and when the spin cycle is going, it makes so much noise and spins so fast I can only assume the thing is so ridiculously heavy to stop it flying away! Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: Top load or front load washing machine 54Jun 03, 2012 8:15 am Having lived in the UK for many years we only had a front loader. We even shipped our UK machine with our furniture and brought it out to Australia. It lasted for about 5 years here and then i purchased a top loader when it finally broke down. I fancied the idea of adding extra clothes throughout the cycle and also the different water levels for small or larger loads. I thought it washed a lot rougher on the clothes with more pilling and more creases than the front loader. I had it for 10 years and when it finally broke down i knew i had to purchase another front loader. With the 30 min cycle and the addition of being able to add clothes when the cycle had started and the gentle wash on the clothes i knew i was on to a winner. No regrets. Hey all Currently renovating our laundry, bought a new washing machine but have found that the drainage hose is alot shorter than the old machine (which I used to get the… 0 17826 Any structural alteration to your home requires building permit. Before you get it you will have to supply plans with structural assessment, you will also be removing… 2 4409 Hi, I'm a newbie to home renovation and was hoping to get some advice. If we wanted to understand which walls and columns are load bearing, is the first point of call to… 0 611 |
